What combination of cam heads and headers
Old Apr 30, 2005 | 08:43 AM
marcdez's Avatar
Default What combination of cam heads and headers
What combination of cam heads and headers should I go with? I want a car that will be reliable and that will also have the power and still Idle pretty smooth. I would Like to get close to 400 horses but I dont know what would be the best set up as far as the headers the cam and heads.
Thanks for any help.
Old Apr 30, 2005 | 09:07 AM
conan's Avatar
Is money no object ? What year is your car ? Do you have to pass a smog test?
Old Apr 30, 2005 | 09:09 AM
slow trap's Avatar
all the usual boltons and can alone should get you around 400 horses.i'd go with any full length header,a cat-back,ory,ported tb ,and a cam in the mid to upper 220s on a 114 if you want it to idle decent and a dyno tune.you will probably need a clutch upgrade very soon also.if you want 30-40 more rwhp than that a set of tea 5.3 stage 1.5s or other sponsor heads that flow 300+ "should" get you there.tea heads work very well with a fms f13 i've heard but can't remember the specs.
Old Apr 30, 2005 | 09:11 AM
slow trap's Avatar
oh yeah i forgot to ask that.ls6 intake also if you don't have one
Old Apr 30, 2005 | 09:40 AM
marcdez's Avatar
Default I can spend enough but like anything I wnat the best bang for the buck
Old Apr 30, 2005 | 09:52 AM
lilbuddy1587's Avatar
best bang for ur buck would most likely be some hooker/pacesetter long tubes, true duals and OR a hooker catback( i say this because its the cheapest, and best sounding with ory and flow is great!) and a tr224 or if u dont mind big but still a little tame the tr230/224, f13, and or a g5x1 are all great cams that would most definately help u achieve ur goals(i know there are other cams out there that are hitting good numbers, im just throwing out a few off the top of my head that are pretty tame). You seem to have the majority of the bolt-ons, but you need to lose that 85mm MAF! Its a bitch to tune with/for tuners to tune. There also isnt really any added benefit as well unless ur going wild cam only or h/c
Old Apr 30, 2005 | 09:58 AM
Patrick G's Avatar
LS1 Tech Administrator
If you don't mind spending some bucks, you can get around 400 rwhp with factory exhaust with Thunder Racing's CheaTR heads/cam package. If you want to go with long tubes, be aware that some severely compromise daily driveability (low hanging y-pipes, stinky off road pipes, bangine pipes).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 30, 2005 | 10:03 AM
conan's Avatar
I am verry happy with my mti heads. Cost was middle of the road. Cams do a search there are hundreds of them. I had thunders 224 cam with full boltons and made 392rwhp 386rwtq. Header check in the external engine section. Kooks/qtps are you top of the line. Also check out jrp's exhaust section. like slow trap said get the ls6 intake H/C need to breathe. I also 2nd getting rid of the 85mm maf, I got lucky with mine and it was able to be tuned. I am ditching it next trip to the dyno.
Old Apr 30, 2005 | 10:49 AM
UtOhCop's Avatar
If i had an F-Body.. I would go with Hooker LT's, TEA heads and probably an X1 cam.
Old Apr 30, 2005 | 12:28 PM
marcdez's Avatar
Thanks For Everything. You Guys And Ls1 Tech Have Been My Best Upgrade So Far.
Old Apr 30, 2005 | 01:00 PM
cyphur's Avatar
read this.
that should help you understand some things about cams and get you somewhat on your way. heads are a personal opinion. TEA, FMS, MTI, all good heads.
