TR 224 cam, what else needed for install
Old Apr 30, 2005 | 04:41 PM
elite22xl's Avatar
Default TR 224 cam, what else needed for install
im looking to get the TR 224 cam for my M6 with 45k miles on it. what else do i need for the install. i looked at the thunder racing kit and im not sure what to get. can you guys help me and tell me everything i need for the install. i dont want to spend too much money on this though. and i want a direct swap on any parts, no modifications of anything. what do i need? (timing chain and oil pump, do i need them for the 224, small cam or?)
thanks J
Old Apr 30, 2005 | 04:52 PM
blkZ28spt's Avatar
You can leave the timing chain and oil pump completely alone and you should be fine. Do a search and read the ls1how.com cam install guide. In terms of parts needed if you buy a cam swap kit they usually come with everything you need.
Old Apr 30, 2005 | 07:26 PM
elite22xl's Avatar
getting excited and i need all your guys help to make sure i get everything i need
Old Apr 30, 2005 | 08:02 PM
WS6FirebirdTA00's Avatar
get a new timing chain, its a good thing to change that sucker out any time you mess with it. the stock oil pump should be good though.
whats your list so far?? you will need spring kit, gaskets, some other little things. i suggest you go to ls1howto.com and read the cam install guide and find out some little things u may need
Old Apr 30, 2005 | 08:26 PM
elite22xl's Avatar
im having my mechanic do the work for me, he wants everything he is going to need to do the install, does not want to car sitting at his shop, wants it done in one shot, anything other then the basic stuff i should have for extra things, and what timing chain did you guys use?
Old Apr 30, 2005 | 08:31 PM
i bought the ls2 chain. are you just doing the cam and nothing else?
Old Apr 30, 2005 | 09:01 PM
elite22xl's Avatar
cam, springs, retainers, pushrods, timing chain
where did you get the ls2 chain?
Old Apr 30, 2005 | 09:05 PM
blkZ28spt's Avatar
http://www.ls1howto.com/index.php?article=23#tools
That really should cover everything.
Old Apr 30, 2005 | 09:08 PM
elite22xl's Avatar
i just wasnt sure what to get being some of the things listed are optional. and the 224 is by no means a "huge" cam
Old Apr 30, 2005 | 09:33 PM
elite22xl's Avatar
http://www.sdpc2000.com/catalog/2267...llet-Gears.htm
can i use this timing chain, i dont want to cut corners but i dont want to spend hundreds on a timing chain
Old Apr 30, 2005 | 10:57 PM
Gloveperson's Avatar
Should be fine with that timing chain.
Old Apr 30, 2005 | 11:04 PM
DocEwww's Avatar
Cam, Vavle spring kit (with retainers, seats, etc), "basic" cam gasket kit, hardened pushrods... are whats needed
ported oil pump, asp under drive crank pulley, timing chain...are good things to swap while doing a cam
Old Apr 30, 2005 | 11:23 PM
dont waste your money on it, ls2 chain is 28 bucks
Old May 1, 2005 | 07:57 AM
elite22xl's Avatar
sounds like the ls2 chain for me, where did you get it?
Old May 1, 2005 | 08:18 AM
sdpc20000.com
email kris about it cuase i dont think they have it listed on the site yet
Old May 1, 2005 | 09:04 AM
elite22xl's Avatar
ok thanks
