Daily driver cam??
Old May 1, 2005 | 04:43 PM
Pavlock Performance's Avatar
Default Daily driver cam??
I want a cam that i can put in for a daily driven m6 formula. i have all the valvetrain, just need a cam
Old May 1, 2005 | 06:26 PM
Bill Bowling's Avatar
Talking
Check out the TSP Torquer Cam. I like mine in my daily driver.
Bill
Old May 1, 2005 | 06:36 PM
co.6z28's Avatar
generally any thing in the 22x-23x can be a good DD. depends on tuning
Old May 2, 2005 | 10:13 AM
what sort of gains have you guys seen???
Old May 2, 2005 | 12:26 PM
blkZ28spt's Avatar
SEARCH. This forum and the dyno results.
And you can put anything that will fit in a daily driver. You personally may not want to drive it, but everybody has their own tolerances and likes/dislikes.
Old May 2, 2005 | 01:58 PM
TheBowtieboy's Avatar
That's exactly what I was going to say.....
It's going to be a personal preference - but a TR224 on a 114 LSA seems to make most happy.
Old May 2, 2005 | 03:14 PM
Derek98z's Avatar
judging from your mods, I'll throw this out there. How about a TR230? I had it for a while. Very good cam and your gears will help.
Old May 2, 2005 | 03:50 PM
SlpLS1's Avatar
Comp 224/230.. i use for daily driver
 Michael S. Palmer
Old May 2, 2005 | 04:06 PM
yungn's Avatar
I like my magic stick V3
Old May 2, 2005 | 04:26 PM
blkZ28spt's Avatar
And mine is in an auto.
Old May 2, 2005 | 04:27 PM
what grind is the magic stick??? My main concern is the crappy 10 bolt with the m6 but i guess i will have to deal with that part when the big boom comes lol! But what sort of gains should i see from a 22X-23X cam??? the car ran a 13.0 with me going a little easy off the line. I drive it everyday so i want something dependable.
Old May 2, 2005 | 04:32 PM
blkZ28spt's Avatar
The magic stick isn't the biggest thing out there but it's not for the faint of heart. 237/242 .603/.609 113
From Texas Speed and Performance. They have several slightly smaller grinds that I personally like the look off as well. I had it down to a TSP or Futral cam, but there are TONS of proven grinds out there. Just gotta pick the right one for your setup, uses and goals.
If you get a cam that large you will want a steep gear (3.73 or preerably 4.10's). The problem with that is that they will make your ten bolt even weaker. You might want to look into a 12 bolt before you put a cam in, depending on how you will use it. (track, sticky tire, etc)
