Casting #241 heads....
Old May 2, 2005 | 02:29 PM
jaxnorth's Avatar
Default Casting #241 heads....
Can someone tell me if these are the standard heads for a 2002 Z/28? I have seen other references that they are corvette heads. The car I purchased was from a dealer and I have no way of contacting the original owner to find out if he swapped heads or not. I would also like to know if there is anyway to tell if I have the Z/06 intake as well.
Thanks in advance...............
Old May 2, 2005 | 02:40 PM
BrentB@TEA's Avatar
yes they came on 2002 cars and yes the intake is more than likely an ls6.. good chance the Block is an ls6 also.
Old May 2, 2005 | 03:03 PM
jaxnorth's Avatar
What are the casting numbers of LS6 heads? Would there be a big difference to bolt those on, or just port and polish my #241 castings?
Thanks.............
Old May 2, 2005 | 03:06 PM
BriancWS6's Avatar
Those 241 heads are stock for your 02 model, as well as the LS6 intake. 01 and 02 cars ALL had the LS6 intake. And as BrentB@TEA said, there's a good chance it could even be an LS6 block.
Old May 2, 2005 | 09:05 PM
BrentB@TEA's Avatar
ls6 heads are casting number 243.
best bet is to pick up a set of stage 1.5 5.3 heads
