The APE 382 is in and running
Old May 3, 2005 | 08:45 AM
1BADAIR's Avatar
Default The APE 382 is in and running
Finally got it in and running
How to install an engine backwards
http://www.mustangmods.com/data/6571/eng1_001.jpg
http://www.mustangmods.com/data/6571/eng1_002.jpg
http://www.mustangmods.com/data/6571/eng1_003.jpg
http://www.mustangmods.com/data/6571/eng1_004.jpg
Start up
http://www.motorcityoutlaws.com/user...r/1badair2.MPG
Old May 3, 2005 | 11:49 AM
10secondZ's Avatar
Awesome man, sounds good!
Old May 3, 2005 | 11:54 AM
Bill00Formula's Avatar
Looks good.
Are you picking up your car using the radiator support?
Old May 3, 2005 | 12:49 PM
CAT3's Avatar
Restricted User
I went through the pics in a slideshow on fast, looped it looks like that car drops on the engine and done in no time.
Old May 3, 2005 | 01:04 PM
1BADAIR's Avatar
Originally Posted by Bill00Formula
Looks good.
Yes, with the engine out two of us could pick the front of the car up so its not too heavy.
Only took about an hour to get it bolted in and wired. Would have been better to put the harness on the engine first but we left it in the car
Old May 3, 2005 | 05:11 PM
Beast96Z's Avatar
I should crank mine this week too. Just waiting on my computer......
Old May 3, 2005 | 08:46 PM
01ArcticSS's Avatar
That would be pretty funny with the guy magically appearing in the one pic and dropping out in the next!
As far is the procedure goes, that is SLICK - I yanked the motor on an 84 Z28 a few (ok like 15) years ago and hated it!
When you get it tuned and broke in post up a vid of a WOT run (if you do those sorts of things!!)
Old May 3, 2005 | 09:25 PM
1BADAIR's Avatar
I will have to get some et radials for the street. I took it up to 4800rpm at half throttle today in third it just spins the Nittos at 26psi.
Tuning in probably two weeks then some WOT video's will follow. Then later this year maybe some 200 shot runs will follow. I don't think the 4.11's will like the N2O. Might have to goto 3.73.
Old May 4, 2005 | 06:44 AM
Shoulder Shaker's Avatar
That looks good. I can't wait to get mine back from APE. It should be fun.
Old May 4, 2005 | 11:46 AM
Camaro_Zach's Avatar
thats not backwards, thats exactly how i have done EVER motor removal/swap on my car. like 6+ times now haha.
Old May 4, 2005 | 12:05 PM
PREDATOR-Z's Avatar
We actualy call that "from the bottom"
Old May 4, 2005 | 12:22 PM
Toonz's Avatar
Ya, I learned of this procedure AFTER I pulled and replaced my motor from the top. NEVER again will I do that.
Very nice sounding engine, APE does some great work and I'm sure you'll be more than happy with their product.
Old May 4, 2005 | 12:55 PM
Stark's Avatar
OMG!! That sounds kickA$$!!
Congrats!
Old May 4, 2005 | 01:05 PM
1BADAIR's Avatar
I took it out the top about six months ago. After some looking I decided it would be much faster to put it in the bottom. I was going to take it out the top but my old garage door was not high enough to get the car over the engine with the door up. Sure glad I moved a month ago.
Old May 6, 2005 | 08:41 AM
1BADAIR's Avatar
Uhh Ohh.
Looks like I have to take it back apart. The rear main seems to be leaking pretty good.
THIS SUCKS
Old May 6, 2005 | 10:15 AM
pewter 01 SS's Avatar
hey man, I have my car without anything just like you did, I ? is did you have to pick up the motor and the tranny at all to install it or did you just drop the car into place.. in a couple of weeks I should be receiveing my motor from ape also and It really seems that thats the easiest way to put it in.....
Old May 6, 2005 | 10:29 AM
1BADAIR's Avatar
We had the engine setting on two car dollies with a 2x10 between them and the trans was setting on an old wooden creeper. The engine/trans was probably 8-10 inches off the ground.
Old May 6, 2005 | 12:52 PM
tdogg5.3's Avatar
Hey, nice work. Questions, what cam are u running? Heads?
