cam for ls6 valve springs
GT2-3 specs: 207 / 220 - .571 / .578 - 118.5 CL
Either way, those are the springs LPE recommends (and sells) w/ the GT2-3.
I have to assume they know what they are talking about..
What is your input on this??
Comp 918's are a very nice spring. I have duals since my lifts are over .600 and they were pretty cheap.... but I wouldn't mind using 918's on my cam even. The 918's were originally rated to something higher than .600 before the 921's came out.
-Gary
IMO, the 918 is overkill for a cam similar to the LS6 or GT2-3. It's the same spring as the 915, but it's wound looser so that spring pressure is higher when installed at 1.800". Basically, it's got more preload and seat pressure, but these cams don't need or want that.
As far as I know, GM does not list any official max lift specs for their beehive springs, so I believe that everything I've read on the internet is opinion. If somebody's got some real GM specs, I'd love to read them.
Coil bind on a beehive spring isn't an easy factor to measure like it is on a regular even wound spring. The bottom coils will start binding at low lift numbers, and the higher ones will be much later. Which coil are you worried about, just the last one? That's not good enough. More importantly, which coil are you going to measure? You have to know what open pressure your cam needs, and use a beehive that will yeild that figure when it's open. The beehives open pressure rises dramatically as you get near max lift, and pressure will be higher than you want before it binds. I've measured my LS6s at .600 and they are not binding.
