Pushrod Calculator
Old May 4, 2005 | 01:11 PM
RX-Ben's Avatar
Default Pushrod Calculator
Attached is a zipped Excel pushrod calculator that I found on LS1tech and then I modified it for easier/more accurate use. (Just unzip it and open)
Some notes:
- 7.38" stock pushrod length is used for the calculations. This is what I found after a bit of research.
- The stock lifter pre-load is about .060" (cold). This works out to be about .050" hot. (Block/head growth will increase distance from cam to rocker about .012"). If you use this calculator you will be calculating for these pre-loads, which is actually a pretty good idea as it will keep valvetrain noise/stress to a minimum, even with Comp Rs (per Tony Mamo's experience).
- Lifter length should only be calculated after the correct lifter wipe is obtained/verified (https://ls1tech.com/forums/showthrea...ht=rocker+wipe). This may mean shimming/milling the stock pedestal, which will affect pushrod necessary pushrod length.
Let me know how it works
Ben
File Type: zip
Old May 4, 2005 | 01:20 PM
GuitsBoy's Avatar
sounds helpful, ill check it out.
Thanks!
Old May 4, 2005 | 01:28 PM
RX-Ben's Avatar
I have an F13 ready to go in as well, just waiting to hear from the machine shop on how wrecked my block/crank is from a lifter needle bearing failure.
Thanks!
Old May 5, 2005 | 09:06 PM
jrp's Avatar
jrp
SN95 Director
you must of dug deep for that one . i found that file a long *** time ago too and saved it as well.
