lifters when doing head install?
Were the lifter cups/trays (same thing) damaged at all? If the cam was burned then you had oil pressure issues. Be sure that all the oil passages are not blocked and you thorougly clean the block/oil pickup screen and put a new oil pump in. Otherwise you risk having the same thing happen again.
When I got my lifter cups from gmpartsdirect.com they were $2.50 each (+their handling fee) but they only come in packs of 5 for some reason.
I drilled out my old clifter , but I wouldn't whole heartedly recommend it unless you have time to spare. You really have to clean up the holes that were drilled to make sure there are no loose pieces that are going to break off and possibly cause damage.
Ben
Thanks
Ben
