cam sensor
Old May 5, 2005 | 01:24 PM
LS198TA's Avatar
Default cam sensor
Is the Cam Sensor next to the Oil Sensor my new FORGED motor wont start just turns over
Old May 5, 2005 | 01:26 PM
jrp's Avatar
jrp
SN95 Director
yes it is. have you checked the crank sensors, coil packs, ect?
Old May 5, 2005 | 06:03 PM
ss rally red's Avatar
JRP is right as usual,but there are SO many other factors why do you single out the cam signal? I might be mistaken but I think the car will still run with a fault there but the injectors fire in a random pattern and the motor will run rough. I just helped a bud install a FMS 408 strocker in his car and it would not fire at all, turns out the heads will milled so far for the 12:1 compression the stock lenght pushrods were not letting the valvetrain opperate correctly,shorter pushrods....and it ran great even on the stock tune. Does it sound like it has compression when you spin it over?
Old May 5, 2005 | 08:43 PM
LS198TA's Avatar
Ok by my mistake i didnt have the crank sensor plugged in. It cranked up my now is running rough. The pushrods i ran in my old setup were comp cam 7350 comp cam had them on back order so the subbed magnuAm pushrods.
Im running the tsp magic stick forged mahle piston and forged rods stock crank also upgraded to the ls6 intake and 28 lbs injectors. Previous dynotune was with a ls1 intake and 26 lbs injectors
Old May 5, 2005 | 08:46 PM
jrp's Avatar
jrp
SN95 Director
lol, i did the same thing with my motor swap. checked over coil packes, injectors, ect. ended up being my crank sensor which i forgot to plug in, cranked up first time when i put it back in.
Old May 5, 2005 | 09:10 PM
LS198TA's Avatar
the only thing i dont have and will be here in the morning is the tempature sensor it got misplaced i heard that if not hooked up it pulls fuel out and wont let it run right is this true cause i have a mis and everything else is hooked up
Old May 5, 2005 | 10:19 PM
LS198TA's Avatar
talk to me JRP
Old May 5, 2005 | 10:34 PM
TJ's Avatar
TJ
those 28# injectors sure are small.
dont blow it up before you get it tuned.
Old May 6, 2005 | 12:35 PM
SlpLS1's Avatar
ya thats tru.. without the temp sensor in there. its not gonna know how cold or hot the motor is.. so its gonna dump fuel.. and timing and all that other ****. id get it in there..well just dont run around like that.
Old May 6, 2005 | 12:37 PM
SlpLS1's Avatar
hows he gonna blow it up with that injector.. its bigger then stock. who cares.. i mean unless he starts putting bottle on it. where he needs the mad xtra fuel. he should be fine. i would reccomend going with at least a #30 lb at least but for now hes ok.
Old May 6, 2005 | 02:43 PM
LS198TA's Avatar
ok got the sensor in there but having major backfire i side is getting hotter than the other side i think it might be my coil pack harness i swapped it to the other side and almost them same thing 1 side is hotter than the other
