H/C install tomorrow
1. any need to take off the A/C condinsor, and other A/C stuff?
2. is it better to do the TB drill mod or just adjust the setscrew to help with idle untill i can get a tune? (searched both questions with mixed answers)
ill be sure to take some good pictures of the install tomorrow and get a 1st startup vid...i been wanting to do this for awhile so im pretty excited!! and alil nervous
wish me luck!
Jon
2. Mess with the set screw.
3. www.ls1howto.com is your best friend
As for the AC, take it off, who needs it anyway! The condenser will get in the way of the cam and I wouldnt drill the TB, you shouldn't need to. I didnt even need to.
Good luck man and let us know how it went!
Jon
Its up to you if you want to take it out or not. It makes it easier. I took mine out along withthe pump and never put it back in.
some things to remember...
1. get a box of nice big zip lock zipper bags and a nice pen. label all the bags and put labels on the bags so you know where they came from.
2. make sure you have the fuel rail disconnect tool (3/8)
3. get plenty of rags and a fender cover would be nice as well.
4. dont forget to soak your lifters and pushrods in fresh oil. i ended up using a nice bread baking pan, it was the perfect size. i ended up needing 2 extra quarts on top of the fresh oil change.
5. get some good loc-tite ($20), and thread sealer for the rocker bolts.
also get a couple cans of degreaser and i used acetone to prep my surefaces. it worked good and i didnt really have anything else.
6. make sure you have both 3/8 and 1/2 drive torque wrrenches (good ones)
7. make sure your timing chain is on the correctly. i tripple quadroople checked it. this way you know its done right.
use regualr oil for the first 500 miles and then switch to synthetic. im just around 400 miles on my new combo and im changing to mobil 1 today.
other than this, follow the ls1how too instruction and you should be fine. make sure you have all the stuff he has listed there before you start, it sucks having to go to the store a lot. oh yeah, make sure you have a big breaker bar too, i have one thats like 2.5 feet long, and it made short work of even the rusty exhaust bolts. make sure you have a new front sseal and water pump gaskets. and when you pound out the old front seal, that back of mine was metal, so it kinda looks like your messing up the cover, but its just the seal. i just took my time, and did a lot of it myself, cause i wanted piece of mind. you shouldnt have any problems, and congrats on the setup. its all worth it when you hear that funker start up for the first time. one more thing, if i were you, id take everry harness off yourselff, and be very very careful. i broke the low oil harness on the pan and one wire pulled out of the map sensor way in back. luckily the dealer had the low oil one and i was able to fix the map one myself. they arent easy to fix, so be careful!!! and a flat razor blade works good to clean the gaskets off, the plastic ice scraper worked for ****. anyway, hope you enjoy and dont forget to heat cycle those springs.
Scott
Unless you want to remove the A/C permanently or risk getting burnt by the R134a, I would not even mess with the A/C system unless you have an A/C machine. Just my 02...
I've spent some time in those base hobby shops . . . we have one here at Hill. If you don't get done in one day, they have an impound area you can put the car in.
Reguardless, either way will work.
ill post a picture when i get back, i have to get some food!
Jon
I still think you're lookin at more then a days work. You're lookin at probably close to three hours just cleaning the deck and bolt holes. It will cut the time in half if your buddy helps.
Just a tip. When you go to take the heads out, take the top bolts out and just loosen the last 10 eough so you can lift the head enough to drain the coolant, but it cant really get into the bolt holes, this will save some cleaning time. Also, ls1howto says to use a razor to clean the deck, but i had better luck with a nice plastic scraper. For the tough areas I got some really fine grit sand paper. Some people dont recommend this, but I had good luck with it, just make sure you dont dig too deep. stuff some rags in the chambers / lifter holes so when you go to clean you dont fill them full of gunk, its gonna get messy, there's no way around it. Hopefully you have some compressed air to help you blow stuff out.
