What could be wrong??
Old May 9, 2005 | 03:04 AM
Silver Arrow's Avatar
Default What could be wrong??
at idle my spark is 25-28 degrees . in first gear it goes all the way up to 40ish ... i shift to 2nd it falls down to 28ish ... 3rd gear falls as low as 18!! i think im getting knock!
and my TPS reads 7-93%
i have a senor on the rear upper part just past the last runner of my FAST 78mm manifold that doesn't sit properly... what does it do, and what happens if it's not seated properly??
and what should my H02S read @ WOT ?
btw, here's a list of what i got on my Holden VX2 SS A4 so that u guyz get an idea of what im running on :
- Pacemaker 4-2-1 headers
- CAPA 2.5" catback
- no cat. converters
- FAST 78mm intake manifold
- FAST 78mm t-body
- LS6 camshaft 02
- LS6 springs
- K&N replacement filter (thinking of getting the K&N aircharger)
- MCAI
- 160 thermostat
- Taylor Pro Race wires
- NGK IridiumIX Sparks
- TCI Performance overhaul kit
- TransGo shiftkit
- B&M tranny cooler
- LS1 Edit Tune
Old May 9, 2005 | 07:50 AM
GuitsBoy's Avatar
If you can scan / log what your timing is, cant you scan what your knock retard is? Then youll definately know if you have any KR or not. Also, the o2s at WOT and high rpm should be around .890 - .910... the narrow band o2s are NOT accurate in this range, so dont rely on this.
Old May 9, 2005 | 08:28 AM
the predator doesn't pick up some of the sensors.. unfortunately knock retard is one of them... it stays at 0.0 all the time!
and the 02 sensor doesn't even get close to .9 ..... i've never seen it hit more then 0.6
Old May 9, 2005 | 08:50 AM
GuitsBoy's Avatar
It should only be around .9 at sustained WOT. During normal cruise, it will fluctuate between 300 and 600 mv., centered around 450 mv (stoich, 14.7:1).
Old May 9, 2005 | 10:32 AM
HBHRacing's Avatar
First off you should be seeing 100% throttle angle. Thats clue number 1. It might be due to the TB change. your going to have to sweep the TPS and see that it reads over 4 volts at WOT.
Next is that sensor. Can you take a pic of it? I can't picture what your talking about in my head right now.
actualy the 02's at idle and part throttle will read anywhere between 1-999 Mv. They should switch above and below bias voltage (450Mv) about 8 times in 10 seconds. During WOT you should se both banks steady out to the upper 800Mv range. but since your not hitting 100% throttle you might not be entering WOT/PE mode so the TPS should be step one.
Old May 9, 2005 | 11:02 AM
GuitsBoy's Avatar
Originally Posted by HBHRacing
First off you should be seeing 100% throttle angle. but since your not hitting 100% throttle you might not be entering WOT/PE mode so the TPS should be step one.
Negative, entering power enrichment is at different throttle position angles depending on engine RPM, but all of them are between 64% and 26% in stock form. Down in the lower rpm, you need to push the pedal past 64%, but once youre already at high rpms, you only have to push the pedal to 26% to enter PE.
Old May 9, 2005 | 11:44 AM
HBHRacing's Avatar
Do you have any documentation as to the specifics of this relationship? I have yet to see this occur.
Old May 9, 2005 | 11:50 AM
GuitsBoy's Avatar
Sure, will this convince you?
Old May 9, 2005 | 12:17 PM
AllThrottle4U's Avatar
Sounds like you have a vacuum leak. When I swapped to the ls6 intake, the map sensor on the back was loose and didn't seal well. I noticed my timing was way up there at wot 36* plus. After I resealed everything it went back to normal. Hope this helps.
Old May 9, 2005 | 01:29 PM
HBHRacing's Avatar
it's a good start.
What temp does the "hot" table come in to play stock? might I also see the cold temp table? by the looks of it at the least it should enter PE mode at 64%. Does this aply to all years?
Sorry for the slight Hijack. I just want to make sure I have it all understood for next time.
Old May 9, 2005 | 01:42 PM
GuitsBoy's Avatar
it's a good start.
Good point. It says "Hot select: 284º F" Which I dont think anyone's engine routinely gets to that temp, so I guess it usually goes off the cold table. There isnt much difference between hot and cold, as cold has the same temperatures except every 26% is replaced by 34%. All other numbers are the same. Im not sure what years share the same data, but I wouldnt imagine any drastic discrepency between any ls1.
Old May 10, 2005 | 02:47 AM
last night i tried playing with my TPS. and if i turn it with my finger i can get it to sweep from 0-100%! but when i put it back on the TB it doesn't, it appears the sweep of the TPS is GREATER then the sweep of the TB shaft. and the ecu re-adjusts itself as well !
my MAF reads 25 lbs/min at WOT. and the timing still retards to 18-20 !! and i reaseled and siliconed the rear sensor.
what should the TPS read?? at idle and WOT??
is 25lb/s min @ the MAF Good?? and is it possible that im maxing out stock injectors?
Old May 10, 2005 | 11:22 PM
How long have you driven the car? Give it some time to readjust. What does tps read with it reconnected to the tb with the blade all the way open? Do you have a newer style tb with a smaller cam and an older style tps sensor? Just a couple of questions for you.
Old May 11, 2005 | 07:15 AM
it reads 93% with the blade all the way open. even if i open the blade 100% and put it back on the TB, it re-adjusts later back to 93% again!
with the blade completely closed.. it reads 7% !!
how do u tell the difference between the new style and old style TPS?? i feel that this is very possible.. as it seems the TPS moves alot more then the blade shaft turns.
Old May 11, 2005 | 09:13 AM
HBHRacing's Avatar
I wouldn't hold too much stock in scanner % readings. Break out a meter and test the signal wire at WOT with the key on engine off and see what voltage you get.
