big cam question guys
Old May 11, 2005 | 05:12 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Default big cam question guys
i have a 408 long block coming in, and it only has 130 miles on it, its got a pretty narely cam like 254 266 around high 630's lift on a 114 lsa, its going into a z06, i got fast 90 and nick williams already got a pretty big hole drilled in it from the previous motor, i was wondering if this thing will be streetable at all, i mean i can deal with little bit of surging and stuff, but not something that will die at every stop light.
Old May 11, 2005 | 05:24 PM
Cal's Avatar
Cal
It won't die at all with the right PCM tuning, but the surging is pretty hard to completely tune out. You can learn to deal with the bucking by adjusting how you drive.
Old May 11, 2005 | 05:30 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
pretty much as long as the sucker idles by itself i am cool, i am used to surgind and bucking
Old May 11, 2005 | 06:11 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
come on guys any more input
Old May 11, 2005 | 07:45 PM
blackbelt's Avatar
yeah put a bigger cam in it Ryne it will solve all your problems....LOL Just send the computer to Jason it will idle...
Old May 11, 2005 | 08:25 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
lol i dont feel like pulling it out lol
Old May 12, 2005 | 03:21 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
come one guys anymore input, on the drivability
Old May 12, 2005 | 03:23 PM
blkZ28spt's Avatar
I'm sure there are others with input, but it's been less than one full day and not that many people can speak in an educated manner about a 254/266 in a 408. Unfortunately.
Old May 12, 2005 | 03:26 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
lol i am young and impatient
Old May 12, 2005 | 04:34 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
It just so happens I have the sound clip of that setup
485rwhp unlocked automatic with a 3800 stall, 3.73 gears with a stock pulley
http://www.texas-speed.com/images/tsp408hyd.mov
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 13, 2005 | 01:12 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i actually expected it to be even choppier then that i think i can live with that as a daily driver
Old May 13, 2005 | 04:39 PM
blackbelt's Avatar
DAM you jason pull the cam put in a 224 and tell him its the big cam he will never know..LOL
Old May 13, 2005 | 04:54 PM
2001CamaroGuy's Avatar
I have a long rod (+0.300"), 388 all bore with a 244/249, 0.640" lift, 112LSA that I drive every day (had to go Speed Density to get a good air/fuel at idle......MAF didn't like the setup)......
it idles really happy at 1K (ie: I can go out in the morning, crank it, and walk off while it warms up.....)......it CAN idle as low as 800 but it REALLY does not like to.....
with your added Cubes it SHOULDN'T be a problem but it all comes down to "Try and you WILL know....."
