biggest cam with 59 cc ls6 'style' PP's
My bud does not want to flycut.
exactly, thats why you can run a bigger cam without flycutting
That being said, what is the biggest cam we can do with unmilled heads?
2001 Z28 M6 car
mti lid
slp 85mm maf
smooth bellows
K&N
LS6 intake
asp pulley
Patriot ls6 heads w/ 2.02 int 59cc chambers
lunati 224/224 .560/.560 112lsa (not as agreesive lobe as a TR224)
edelbrock longtubes
true duals with bullets dumped before the axle
w2w dyno tune
dynoed as follows:
mustang dyno: 351.5rwhp 323rwtq
dynojet: 405.3rwhp 375rwtq
Personally, i want more power, although i can tell my car is a hell of a lot faster than it was. im going to wait till i stroke my cam and put in a bigger cam. the valve size is all that limiting your cam lift, cause these heads are unmilled. id say go with something al least in the 230 range at .050. a lot of people recommended the tsp 233/239 cam to me, but that lift may be too much for you. call around and ask, but id go with at least a 231/237 and something in the .580's lift area. prob a 112 lsa for motor or 115+lsa for boost. hope this helps...
The heads are not milled. They have 2.055/1.057 valves. The F13 should be pretty nice.
A good 'first cam' for him. The heads are not milled. They have 2.055/1.057 valves. The F13 should be pretty nice.
A good 'first cam' for him.With the 2.055 valves you will lose about 0.0074" of p/v clearance versus a stock valve. Compared to a 2.02 intake you will lose about 0.005". Not much.
You basically have the same clearances that I will have overall. I got 5.3L heads that are milled .006" to up my compression slightly. The F13 cam should work fine with those heads. Allan Futral said I could have my heads milled .015" and still clear OK (using stock MLS gaskets). There are also a few guys on here running more mill than that, but there cams are for the most part not off-the-shelf grinds. Mine is just the regular 112LSA, +4 advance. Sounds like you won't have problems running those heads and the F13
Now, the only concern I have is valve drop. I am not familiar with how much drop PP heads have. You might check on that.
