Fm13 Just installed TODAY...
Old May 11, 2005 | 11:49 PM
joshp14's Avatar
Default Fm13 Just installed TODAY...VIDS!
Just finished my F13 install...I did it over 3 nights so I didnt overload myself.
Went with the Dual PRC spring Kit with Ti Retainers, CM Pushrods, ASP underdrive pulley, LS2 timing chain, and a 160 stat while the pump was off.
I fabricated my own spring compressor similar to the Larry tool, and it worked awesome. Everything else was cake...even the pickup tube bolt
All in all the install went fairly smooth with the exception of the broken oil pan bolt which took 2 hours to get out off the block....
Adjusted the timing tables, bumped up the Rev limiter to 6600, speed limiter to 200 , adjusted the fan settings, etc. Have to do some logging yet to watch my fuel trims, but I'll take her out tomorrow after my 1 heat cycle for the springs is over with.
I have a video of the initial startup and I'll post it soon....WOW this GMMG/LT's/FM13 is A M A Z I N G!
VIDS HERE:
http://www.midwestfbodymeet.com/01TAPics.html#videos
Old May 11, 2005 | 11:58 PM
joshp14's Avatar
On another note, these PRC springs are amazingly quiet.
Here are some methods I used:
-I used two 1/4" brake lines to hold the lifters up
-I used the longer crank pulley bolt to install the new pulley
-I used my Air hold adaptor out of my compression set to hold the valves closed while changing the springs
-I went DOWN with the condensor and set the corner on a bucket. This put less stress on the A/C lines then when you go up with it instead.
-I used mechanical fingers to get the oil pickup tube bolt in place and started.
-The TB came off before removing the water pump so I could get it out easier
Old May 12, 2005 | 07:40 AM
Bigrob339's Avatar
Awesome, that is the cam i am wanting to install, let me know what it does on the dyno, and lets see that video!!!
peace rob
Old May 12, 2005 | 08:47 AM
Shu's Avatar
Shu
Nice, you won't be dissapointed with this cam!
Old May 12, 2005 | 12:17 PM
joshp14's Avatar
I hope not...I'm takin it for a drive today!
Old May 13, 2005 | 05:39 PM
SlickVert's Avatar
Good luck!
F13 cam rocks
Old May 14, 2005 | 08:11 AM
Stark's Avatar
Congrats on your new cam!! You'll love it!
At stop lights, when your car is gently shaking out that lope,
TRY not to smile. I dare you.
Old May 14, 2005 | 10:17 AM
pntballty's Avatar
Awsome, we are putting my buddies F13 in today, well actually all we have left to do is swap the springs.
Old May 14, 2005 | 10:23 AM
Screamer27's Avatar
Come on, where is the Vid Josh!!
Old May 14, 2005 | 07:00 PM
joshp14's Avatar
Lol..well we are still trying to get the idle bug worked out via EFI-Live...it bogs down when you push the clutch in and the RPMs drop from above 1K RPM..other than that it runs awesome.
Old May 14, 2005 | 09:54 PM
Checkmate's Avatar
congrats, i had some issues with my idle as well. Still not perfect but much better.
Old May 14, 2005 | 11:26 PM
lsevenl's Avatar
My f13 and patriot golds are going in tomorrow morning, along with a host of other goodies.
Old May 15, 2005 | 12:25 AM
1FASTBIRD's Avatar
I can't wait to finish my install on monday. Dude can't wait to hear the vid on the way it sounds on your car and the dyno #. I can't wait to at the track and at some local pony boys
Old May 15, 2005 | 11:27 AM
ss2000's Avatar
this is a great cam. i have my rev limiter set at 7000 and i shift it at 6700. the tsp true duals make it sound even better. i still have stock heads and went 11.59 @118 last weekend.
Old May 15, 2005 | 09:13 PM
joshp14's Avatar
Im heading to the track on saturday so I hope to be in the 12's
Old May 15, 2005 | 09:29 PM
WS6FirebirdTA00's Avatar
i want to hear a video, hope i can start mine up this week shoudl sound bad ***! even if its a bad one just email it to me, my car has been appart 2 weeks waiting for an oil pump!!!
Old May 15, 2005 | 09:30 PM
ss rally red's Avatar
FMS cams rock Although I have done so many cam & springs we have it down to 4 hours-4hrs 30 mins, it is very satisfing to do it yourself, congrats on the install
Old May 15, 2005 | 09:56 PM
00SSLS1's Avatar
just finished my f13 install minutes ago
Old May 15, 2005 | 10:36 PM
joshp14's Avatar
GOT THE VIDS:
Old May 15, 2005 | 10:44 PM
damn so now i have to wait for my oil pump before i can hear it on mine!! damn kinda makes me wanna slap the old pump on to just hear it lol
