Need help installing Manley springs
This is the spring set i got with my F13 cam:
FMS Cam Kit - Manley Dual Spring Kit - $740.00
FMS Hydraulic Camshaft
FMS Hardened Pushrods
Manley Dual Valve Springs (rated to .650 lift)
Manley Titanium Retainers
Manley Locators
Valve Stem Seals
I didnt get any locks with my kit, i was wondering if im supposed to reuse the stock locks, or if the kit was supposed to come with them.
Also where does the shim go? Does it go on first then the seat? First time doing this obviously any help would be much appreicated.
Thanks guys, Justin
Manley Locators
Valve Stem Seals
Thanks guys, Justin
I don't know what type of locks you have stock, so I wont comment on the
valve locks.
If you have the cash, I'd buy new locks. They are about $20.00 for a set.
The shim sits on the head (between the head and the spring).
No shim
Shimmed
valve locks.
No shim
Shimmed
Thanks for the help guys, now i know where the shim goes.
Im using the Manley Titanium Retainers that i got with my spring kit, but it didnt come with any locks, can i reuse the stock locks?
Thanks again, Justin
You are better off getting some Manley machined locks, they are for heavy duty applications, although the stamped OEM's rarely fail.You need to get a valve spring height micrometer so that you can shim the springs for the correct install height on the springs. Depending on the install height the spring pressure will vary. Also for larger cams install height comes into play with coil bind, NOT good.
