Comp 921 duals or PRC gold duals?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by hoserack
I was in a shop recently dicussing which duals I was gonna upgrade to.
The guy had every phucen spring that you could think of in there and I beleive he found the Cranes to be working best.
I'll call tomorrow to double check. and call you.
This guys said 921's are **** and and they also lowered the 918 singles to 600 lift so they could sell the more expensive 921'S.
Before the 921's came along the 918's were rated to 650.
Originally Posted by blkZ28spt
Over 7,000? That is seriously high, and is asking for a lot out of a hydraulic roller setup. Let alone the bottom end....
Originally Posted by verbs
The my Canes sucked compared to my 921s. The Cranes have a lot less open and closed seat pressure and were causing problems with my G5X3 cam. Swapped em out for 921s and no more problems
Originally Posted by Terry@RacetechSpeed
IMO the PRC is the best spring,dollar for dollar.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
The comp 921 is a good spring.Just because it cost more doesn't mean its superior to the PRC spring.IMO the PRC is the best spring,dollar for dollar.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Talked to Berry today and he said the Cranes don't have good pressure, 918's have more.
He said the only drawback with the 921's is travel, he said they coil bind quicker than most others then there is still the issue of bad harmonics.
The beehive design is the best.
But I know you have to have the duals.
The 921's will work for you.
Now get that bitch runnin you slacker. lol
