question about timing chain slack
Old May 15, 2005 | 09:32 PM
WS6FirebirdTA00's Avatar
Default question about timing chain slack
well i got my chain on and the dots line up when i turn the motor around each way, but i notice one side is tight and the other is loose. im using a new ls2 chain and dont know if this is just normal. wanna make sure before i get it all back together
Old May 15, 2005 | 10:15 PM
racecar's Avatar
My new Crane double roller is pretty loose also. I removed the front cover after running the motor ten minutes and was surprised to see how loose it is.
GM makes a dampner. It is just a piece of plastic that the chain rubs on to help keep the slack from bouncing. There is a picture in Handzels book pg 113. P/N 88958607 It was way over priced because it never made it into production. I bought it because it may help to keep things under control at high RPM.
Old May 15, 2005 | 10:24 PM
thanks for the response, i kinda figued it would be tighter than it was
Old May 15, 2005 | 10:40 PM
ChameleonBird's Avatar
i think its pretty normal for any chain assembly to have a side that is tighter than the other, you want some slack
Old May 15, 2005 | 10:42 PM
good, thanks lol thats what i thought but i just wanted to be sure, it was my first cam install and went really easy, so i wanna make sure it was all done right. kinda had to sit back and think was it really just that easy or did i not do something right lol
Old May 15, 2005 | 10:49 PM
i know the feeling.....
what did I forget?
