cam install
Old May 18, 2005 | 08:26 AM
raginazn616's Avatar
Default cam install
i'm about to purchase a cam, and i was just wondering what all i need to do it right? it's not a big cam so i don't need headwork or anything. but one person told me i needed jus the cam, and somebody else told me i needed new springs, hardened pushrods, head gaskets, water pump gasket, and a mandatory tune . i've got a m6 so i'm not too bad worried about the tune right now, but can somebody please clue me in...thanks
Old May 18, 2005 | 08:32 AM
Adrenaline_Z's Avatar
I'd also invest in a cam degree kit. Always degree the cam.
Lining up dots doesn't ensure proper centerline phasing.
If the recent posts in this forum aren't enough to justify the cost, I don't know
what is.
Old May 18, 2005 | 08:40 AM
hourang's Avatar
at a minimum, you need a spring kit, hardened pushrods, water pump gaskets, timing cover gasket, crank pulley bolt, and the cam. whats recommended to do at the same time is a timing chain, and ported ls6 oil pump, i didnt on mine and now i have to tear everything back down to do it again. degreeing the cam is not required, but its good piece of mind, most ppl dont do it.
Old May 18, 2005 | 08:51 AM
RaNsOm's Avatar
http://www.ls1howto.com/index.php?article=23
Old May 18, 2005 | 01:54 PM
that's the most help that anybody has given me...thanks!
