redline?
Old May 24, 2005 | 08:11 AM
raginazn616's Avatar
Default redline?
what sets a cars redline? the computer sets the rev limiter right? but what about when a cam makes power up to 6800? with hardened pushrods and better valve springs can it rev higher than stock redline without messin sh*t up and breaking something?
Old May 24, 2005 | 08:51 AM
XTrooper's Avatar
The "redline" is the term used for the maximum safe engine speed for your motor. This should coincide with your rev limiter setting.
Your engine's redline will rise as you put higher quality, made-for-racing components in it. These parts are made for higher engine speeds so they shouldn't break.
In the old days, you were the rev limiter. Now the PCM handles that chore.
Old May 24, 2005 | 08:57 AM
99SilverZ's Avatar
I have changed out my cam, springs and rods too. Since then, I have raised my rev limiter to 6800RPM (HPTuners). I dynoed last week and ran all the way to 7000 and still making power. I would say it is safe to run that high at times but keep up with the maintenance to avoid regrets later.
Old May 24, 2005 | 09:04 AM
conan's Avatar
When I had my TR 224 I would spin mine to 6,800 rev set at 7,000 no problems here. If you get you dynoed they can tell you what rpm your cam falls on its face.
Old May 24, 2005 | 09:08 AM
XTrooper's Avatar
Keep in mind that when your engine speed reaches ~7000 rpm, not only your valvetrain, but the bottom end becomes a consideration (rod bolts, etc).
Old May 24, 2005 | 10:35 AM
with my comp cam (2200-6800 power band), 918 springs, and hardened 7.400" pushrods...what should i shift at for racing? 6500-6700? somewhere along those lines? or would i be safe to run the full 6800? i'm gonna get dynoed sometime over the summer...i'll find out more then, i'm just curious now...lol
Old May 24, 2005 | 01:27 PM
XTrooper's Avatar
Get dynoed, see where your motor makes its peak hp, and go from there.
Old May 24, 2005 | 03:00 PM
RedHardSupra's Avatar
i made a spreadsheet that will explain to you how much you can gain/lose by playing with shiftpoints and gearing. lemme know what you think. soon i'll post a new version that will show you graphs of it all
http://redhardsupra.blogspot.com/200...ft-points.html
Old May 24, 2005 | 03:05 PM
~JOSHUA's Avatar
I just dropped in a cam and I still shift most of the time at the stock 6,000 rpm even though the engine is still pulling strong. If I have a race then I can stretch it to the limiter that I set with the Crane cam tuner. No need to rag your car out if your not "needing" to.
