Why do the Crane 832's need to be shimmed
I don't believe it's good practice to install such a heavy shim when it cuts
into bind clearanace and spring harmonics.
If one, or two valves are out by 0.030", you might want to shoot the tech
that did the valve job.
If all of the valves need that much shimming, you would be better off to change the
install height, and cross reference a spring with similar open height pressure.
Of course, this is my opinion.
install height and cross reference a spring with similar open height pressure.
How can a spring that is slightly compressed have the same harmonics as
a spring sitting at full install height?
The dynamics are already different from the start.
The shim set that Comp Cams sells comes with 16 shims each (48 total) in .015", .030", and .060" thicknesses. These are the same standard thicknesses that have been used forever.
http://store.summitracing.com/partde...=KeywordSearch
rarefaction at open height? Wouldn't you be a little worried cutting into
the clearance by 0.030" @ 6200 RPM?
of the valve work or spring.
I understand the need to shim springs to get the correct pressure. Don't
misread what I'm stating. I have shims under my springs as well.
What you both are misunderstanding is...0.030" correction for a spring is out
of spec.
If all of the springs are installed at 1.8" and ONE, or TWO springs need a 0.030"
shim to correct the pressure @ 1.770" ...don't you think those springs need to be
swapped out?
That's not the part that bugs me, it's the fact that coil bind comes sooner
and the clearance window is totally off.
OR
If all of the springs are isntalled at 1.8", and ONE, or TWO need 0.030" + shims
to correct a crappy valve job, you'd be happy with that? Sure the springs
are all at 1.8" again, but I'd be handing the heads back to the tech and
get some new valve seats installed at his expense.
Unless you like variance in combustion chamber volume
If I'm using a 0.030 to 0.060" shim in my valve train, I question the quality
of spec.
swapped out?
OR
cylinder heads instead of trying to apply what you read...to something
you don't quite understand.
Everything in my reply is solid.
If you think adding a 0.030" shim is normal, I question your understanding
of machine work and tolerances. Either that, or the spring selection is way
off.
pressure (at least I am).
In all fairness, I re-read the post from top to bottom, and I see that the
discussion refers to another revision of spring on the lower half of the first
page.
What started out as an opinion (Post #24), has turned into a battle.
If you need to shim to get the install height - fine.
If you need to shim to get pressures:
a. Do you have the best suited spring?
b. Are you sacrificing clearance, or spring characteristics?
My position to clarify once again:
A 0.030" correction shim is out of spec IMO. A spring that sits at 1.770" with
125 lbs. seat pressure has a different spring rate than a spring that sits at
1.800" with 125 lbs. seat pressure.
The harmonics throughout each spring in the above scenario will be different.
I would not want a few of my springs shimmed at 0.030" or more, where the
others are at full install height.
As for shimming all springs for seat pressure, I would much rather install an
offset lock, or retainer ... or select another spring before I cut my open
height and clearance by 0.030"
Again, this is my opinion. It's an alternative to setting up a valve train
for correct pressures while leaving enough clearance for high RPM use.
page.
then...not one size fits all with shimming?
I would think shimming is to balance the entire train pressures.
In any case...to each their own.
Maybe you can point me towards this magical mountain of springs.
I'm sure there's a few different MFG's and spring types to choose from.
Even if those aren't enough, you can always machine the heads to accept
a wider range of spring.
