Will bent pushrods kill HP?
Old May 25, 2005 | 12:30 AM
02WS6#519's Avatar
Question Will bent pushrods kill HP?
I pulled the valve covers off after hearing a knocking sound from the engine. I checked the pushrods and they were all bent a little and 4 of them were more noticeable than the others. Will they hurt hp? Which pushrods should I get? What length? I have a XER 224/224 .581/.581 112lsa with un-milled heads(2.02/1.60 valves).
Thanks in Advance
Ever
Old May 25, 2005 | 12:35 AM
CAT3's Avatar
Restricted User
You probably missed a shift is my guess, thus bending the prods. Yes they will cause a lack of power as the valve cannot open to its full extent. Other damage can happen from this as well. I suggest getting some hardened pushrods, 7.400" drop in and retorque rockers to 22#'s. If you tend to miss a lot of shifts, might want to just get some more stockers, safer for you that way instead of wiping out the lifters, valves or anything.
Old May 25, 2005 | 12:48 AM
02WS6#519's Avatar
Will it hurt hp enough for -.1 or .2 at the track?
Peace
Ever
Old May 25, 2005 | 01:47 AM
CAT3's Avatar
Restricted User
Hell yes. It can also cause more than just a lil off time.
Old May 25, 2005 | 02:05 AM
SStrokerAce's Avatar
Yeah they will hurt the power.... This time upgrade to a better quality pushrod. If you are bending them from a missed shift they are not stiff enough so you need to either get a higher quality one or go to a higher quality and a larger size. 1.7:1 Rockers play hell with pushrods.
Bret
Old May 25, 2005 | 06:09 AM
PREDATOR-Z's Avatar
That is why I love autos for the strip
Old May 25, 2005 | 08:51 AM
SSick's Avatar
I got my 7.4" set from thunderracing their consierably stronger than stock have a bigger oil ports and have taken a beating from a few miss shifts on my TR230 equipped M6 ride. I'm a fan!
