Oil in heads.......?????
I have got a good idea of whats wrong but alot of you guys have much more knowledge than me.First off the car would idle fine, but would not take any load what so ever. The motor was built wrong. It was supposed to be 11:1 but is somewhere south of 9:1, it was supposed to be NA with the possibility of spray. He used Diamond -8.6 cc dished pistons when I wanted flat tops w/valve reliefs. He used TRW rings on my diamond pistons, and he also used the Eagle 6.100 rods instead of the 6.125, gaskets are .054 felpro's, and the heads are TEA 5.3's milled .010. Motor only has 1,7xx miles since rebuild.
I pulled the heads off yesterday, and granted the PCV didn't look like it was in good shape, the heads were coated with oil, especially on the intake side, I mean covered, the intake also had a good amount of oil. The car never let out any white or blue smoke from the exhaust.
How bad is this, and what can I do to fix it. I don't have a high pressure pump, just an SLP Heavy Duty oil pump
Also, tons of people run with breathers instead of a PCV, correct? What kind of filters are you guys using for this?
