everyone with pp stage 2 5.3 heads needed
Old May 27, 2005 | 01:37 PM
REDWS6ROCKET's Avatar
Default everyone with pp stage 2 5.3 heads needed
what cam are you guys running. stangkilr and i just traded cars and currently the car has patriot 5.3 heads comp 230/220 .581/.581 112 lsa (which was a custom grind for another car) longtubes, lid, 3500 stall. that car is not daily driven. i want a recomendation on a cam from you guys. i have been searching am considering a tr230 and tsp 228 any others you can think of. i want to stay right in the middle range for a cam nothing small and nothing huge. thanks steve
Old May 27, 2005 | 01:40 PM
cyphur's Avatar
Futral Motorsports F13 114+4 should do you just fine
Old May 27, 2005 | 01:41 PM
CAT3's Avatar
Restricted User
Running a TSP 231/237 112*. Seems to work well, better then the small TR @ 224.
Old May 27, 2005 | 03:31 PM
WOT's Avatar
WOT
i used to run the same heads and a 231 / 237. with all bolt ons i got 448 / 410 out of it. it was a nice combo for the street and strip. nothing too radical and nothing too lame. This was a M6 though. not sure what some of the A4 guys are getting out of it.
WOT
Old May 27, 2005 | 04:13 PM
Tally TransAm's Avatar
f11 (228/230 581/595 112 +4)
wish i could go bigger but my heads are cut and im not sure how much bigger i can go
car runs good though, has gone 11.5 @ 121 on a 1.68 60'. itll go faster
Old May 27, 2005 | 07:48 PM
JoeyGC5's Avatar
The Futral FM-11, or 12
Or the Texas Speed 231/237 will really wake Justins old car up
Old May 27, 2005 | 09:25 PM
Charles Cyrus's Avatar
FM-13.......11.14@120mph.
Old May 28, 2005 | 12:58 AM
blacktransam's Avatar
check my sig
Old May 28, 2005 | 11:33 AM
JGKadell's Avatar
FM-11, 13, or 14
Old May 28, 2005 | 12:54 PM
Default thanks
thanks guys i have been looking really hard at the tsp 231/237 after all the posts. any more feed back would be great.
Old May 29, 2005 | 11:16 AM
JoeyGC5's Avatar
that car has a 3200 stall right?
Old Jun 16, 2005 | 04:32 PM
well i think i am going to do the tsp 231/237 cam, tsp ported pump, comp oe lifters, and ls2 chain. any more suggestions would be great. i talked to trevor at tsp he said to use the torquer rev. 2 cam which if i remeber is a 232/234 .598/.595 112+2 any one here currently running it or used it. thanks guys
Old Jun 17, 2005 | 08:11 AM
PREDATOR-Z's Avatar
Why not see what your combo does now and fine tune it? Then if not satisfied at least you understand where you stand.
That Comp cam is a powerful cam with XE-R lobes. With good exhaust flow and good headers, I'm sure it will perform within the power range of all the cams mentionned above by other members.
Old Jun 17, 2005 | 09:41 AM
the in it now is fun but is was custom made nitrous cam for some one elses car. it put down 367/341 on the dyno and went 12.3 @ 110. that cam is not taking full advantage of those heads. i know alot of it is in the tune. but there is alot more power to be gained from a cam swap.
