Cam Emissions
Old May 31, 2005 | 08:49 PM
travis00's Avatar
Default Cam Emissions
Will a big cam like a TSP Magic Stick (237/242 .603/.609 113lsa) pass emissions?
Old May 31, 2005 | 09:12 PM
conan's Avatar
With a good tune It might, thats prety big. Are you running lts? Are you keeping all your emission controls?
Old May 31, 2005 | 09:25 PM
travis00's Avatar
Yes,
I am running lts and all the emission controls.
Old May 31, 2005 | 09:34 PM
conan's Avatar
Have you passed W/ the lts? I have read people having trouble passing because the rear 02's were moved back and not operating at full temp.
Old May 31, 2005 | 10:24 PM
travis00's Avatar
Yes I passed with the lts. Someone told me that I wouldn't pass if I had a cam any bigger than a 224/224 114lsa. But I find that hard to believe.
Old May 31, 2005 | 11:26 PM
BlueSix's Avatar
If you have to pass the sniffer then there's no way in hell it'll pass. If it's only a visual inspection and you can get by with your current setup using the long tubes than changing the cam won't change anything.
Old Jun 2, 2005 | 09:57 AM
darrensls1formula's Avatar
Well you should believe it because it's true. At least for a sniffer test it is. I have heard of a few people passing with slightly higher cams 228/228 112 or even 231/231 114 but that takes one hell of a good tune.
If your emission testing does not require a sniffer test then you can get away with a lot bigger as long as the computer isn't throwing any codes which again comes down to a good tune and a great tuner.
Good luck
