Did a search on tapping out the crank, and found two different answers..
Old 06-01-2005, 11:02 PM
Captain InsaneO's Avatar
Default Did a search on tapping out the crank, and found two different answers..
It appears my stock crank bolt got torqued in too far and messed up the last 3-4 threads on the bolt. I am going to have to tap the crank. I believe the bolt is a 16 x 2.0 but I see many guys saying to use a 16 x 1.2 tap. Which tap do I use, a 16 x 2.0 or 16 x 1.2?
I have a line on a 16 x 2. 6" long tap, I hope I can find the same in a 1.2 if I need to.
Old 06-01-2005, 11:19 PM
sandking's Avatar
16x1.20 is the right one.
Old 06-01-2005, 11:21 PM
Grimes's Avatar
i believe the M16x2.0 is the one
lol, 2 different answers, but i'm 99% sure on this one, cuz i ordered threaded rod to install my asp pulley and it was 2.0 and it fit!
Old 06-01-2005, 11:22 PM
omg...
Grimes's Avatar
hold on i will check a parts manual for you
Old 06-01-2005, 11:25 PM
I know the bolt is a 16 x 2.0 I had it measured at a machine shop, but since I am ignorant to all this, I didn't know if I am to use a tap the same size as the bolt (which makes sense) or use a 16 x 1.2 tap for reasons I am not aware of.
Old 06-01-2005, 11:28 PM
Grimes's Avatar
Just checked and it indeed is M16-2.0
And yes, you need to use the same size tap
Old 06-01-2005, 11:30 PM
Thank you for helping me. I really appreciate it!
Old 06-01-2005, 11:31 PM
Grimes's Avatar
No problem...glad to help!
Old 06-01-2005, 11:42 PM
Oh one other thing, I am told theres different points to choose from when it comes to a tap. I guess it matters? Heres the one I am going to get, its spiral tipped.
http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=2712560
I suppose that one will work fine?
