Eagle cranks?
Old Jun 2, 2005 | 09:52 AM
FastKat's Avatar
Default Eagle cranks?
Seems like Eagle cranks have a bad wrap here on LS1Tech... any reason? have people had bad experiences with them?
I know there are awesome deals out there on Eagle 4" stroke LS1 cranks... sometimes you get what you pay for... and sometimes you get a deal!
Old Jun 2, 2005 | 10:12 AM
GuitsBoy's Avatar
Eagle used to have problems. They are now resolved. Many reputable sponsors build great motors with eagle components.
Old Jun 2, 2005 | 11:51 AM
MeanWS6's Avatar
no problems here
Old Jun 2, 2005 | 03:22 PM
Beast96Z's Avatar
They caught a bad rap when the were first released for the LS-1's. The had some problems that have since been re-called and fixed. Almost every sponsor now uses them for there budget stroker kits. If your gunna run big power adders, I still recomend something better like Callies or Lunati.
Old Jun 2, 2005 | 04:01 PM
99FormulaWs6's Avatar
Would you run an Eagle assembly with a 150-200 wet shot?
Old Jun 2, 2005 | 04:06 PM
GuitsBoy's Avatar
You can pretty much run that on stock internals
Old Jun 2, 2005 | 04:07 PM
SuperZ's Avatar
O yeah the eagle rotating assembly would be more than enough for a 150-200 shot.Keep in mind the stock LS1 crank will hold a crap load of power so anything forged will be significantly better.
Old Jun 2, 2005 | 04:56 PM
ChucksZ06's Avatar
I am assembling an ls2 with a 4 in eagle crank and 6.125 eagle rods. I am using mahle pistons and there was a clearance problem with the counterwts hitting the bottom of the piston. I had to remove .050 from affected counterwts and have crank rebalanced. I now notice that Eagle uses 6.2 rods in the 4 inch rotating assemblies. Live and learn. I wonder if Eagle uses a larger counterwt to save money on balancing with mallory metal? Other than that the dimensions on the mains and rods are nuts on and it seems like a quality item.
