5.3 and 6.0 external differences
Old Jun 2, 2005 | 09:15 PM
Lason's Avatar
Default 5.3 and 6.0 external differences
I THINK I found a 6.0 complete motor for free but before I go through the trouble of pulling it how can I tell for sure its a 6.0 and not a 5.3? I just want to make sure its worth my time to pull it. BTW it has been through a fire so the intake and all plastic pieces and even timing cover and valve covers are gone.
Old Jun 2, 2005 | 09:17 PM
jrp's Avatar
jrp
SN95 Director
PT# on the block or just measure the bore; 3.779 (5.3) vs 4.00 (6.0)
Old Jun 2, 2005 | 09:18 PM
Lason's Avatar
where are the casting numbers on these blocks? It is complete so the heads are still on it and I dont want to pull them unless I have to.
Old Jun 2, 2005 | 09:28 PM
Lason's Avatar
Actually JRP, I found alot of good info in your sig. I MAY be able to identify this motor using that info, thanks!
Old Jun 2, 2005 | 09:58 PM
rosscob's Avatar
A 6.0 block will have it's size cast into the block.
Old Jun 2, 2005 | 10:00 PM
Lason's Avatar
Yeah but isnt it in the back in the bellhousing area? This motor still has the tranny bolted to it and I plan on seperating it IF I find out its a 6.0, otherwise Im passing on it.
Old Jun 2, 2005 | 11:26 PM
ArcticZ28's Avatar
Heads are casting number 317. The block will be black (not silver) and made of iron (aka a magnet will stick to it). That should be enough to identify.
Old Jun 2, 2005 | 11:32 PM
jrp's Avatar
jrp
SN95 Director
317's castings started in 01', it could be a 99 or 00 which used an iron 873 cast head.
also the 5.3 block is black and iron as well.
Old Jun 2, 2005 | 11:53 PM
ArcticZ28's Avatar
note to self: research more into such differences instead of questioning and hoping to get lucky with a response.
Old Jun 3, 2005 | 01:48 AM
strokedls1's Avatar
The 6.0L is cast into the block on the front of the motor right below the passenger head.
Old Jun 3, 2005 | 04:43 AM
VA2001SS's Avatar
Casting number is 12551364 on LQ4/LQ9 blocks.
