cam experts step inside-->
i had a cam in my 99 ss (224 224 .563 .563 from thunder racing) and i loved it. i pulled really nice, but it loped alot and it wasnt in my opinion too bad for what it was, but i would like a cam that lopes less, but pulls just as hard.
i have been looking at different cams, but i cant make up my mind as far as what cam to go with. i would like a cam with pull all the way to nearly 7k and that doesnt idle too " crazy", but that u can still tell there is a cam in there.
Is there a cam that can put me close to 400 rwhp with stock manifolds?? i am currently at just a a little over 360rwhp..(362rwhp to be exact). i am also going to add a varam intake, but everything else will remain the same.
let me hear some suggestions....
This CheaTR cam will do it with a set of heads.
You might be close with a Z06.
Also there is the MTI StealthII 224/220, .581/.581 116
IMO you first mod should be a nice set of stainless LTs like LG's. You'll gain more with them than a cam.
PREDATOR-Z gave you some good suggestions also, and I agree, you NEED some headers. Were you planning on staying with stock manifolds?
if you aren't going to get LGs headers, at least port out your stockers. putting in a cam w/an otherwise stock car is not going to give you the results you want.
edit: Turo, you're talking about Patrick G. he also had the more restrictive F-body headers, and this guy does have LS6 heads and freer flowing exhaust.
But if he does a search, there is a Z06 with Stealth II, headers but cam only making 402 at the wheels.
lg headers are over priced if you ask me, but to each their own.
LGs are the best, you can get Kooks for around $850.
Also a cam change is around $900 or so on average and that for ~20rwhp!!
Use something similar on a 114 LSA and it will be noticably smoother and make similar peak HP and TQ (slightly less down low).
DON"T use a reverse pattern with a restricted exhaust (ie. exh. manifolds). It will be down on power, especially upstairs.
I have ran a 224/228 on a 114 LSA and I found it to be quite stealthy. Just a slight amount of "lope" at 850 RPM's and perfect "stock like" driving manners while still being capable of pulling hard to 7K with the right induction and cylinder head mods.
GREAT choice for a dual purpose street cam.
(A 224/224 will idle slightly smoother and give up about 5-6 HP to the 224/228 at higher RPM's)
Tony M.
EDIT: Also, use an XER lobe (or similar)....they have less advertised duration which has a big impact on idle quality and more area under the curve (which has a big impact on power!) I bet the 224/228 cam in my car would idle smoother (than your previous 224/224) AND make more power due to the LSA and the different ramp designs. You will also get more lift with the faster ramps which is another benefit that helps power output.....Good Luck
These were the principles that led to the development of the Thunder Racing CheaTR camshaft. Overlap is around -11 degrees at .050" (for very smooth idle) and the greater exhaust duration and early opening give the exhaust enough time to leave the cylinder. On a Z06, since the exhaust is better than the F-bodies, you could probably get by with a little later exhaust opening and a little less exhaust duration. If you want a smooth idle, I'd recommend keeping the overlap between -10 and -5 degrees. Here's what I would recommend for a Z06 running stock manifolds.
220/228 .595/.598 (XE-R) 115LSA, 114ICL. You get an intake closing point of 44 degrees ABDC for peak power at 6300 (and it will pull to 7000), exhaust opening point of 50 degrees and overlap of -6 degrees at .050".
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
i have been thinking about that cheater cam, but are there any other options? also, i was truely considering the new 232/238 tsp.
I've seen 400rwhp Z06's with just bolt ons and a good tune.
Vararam, ported TB, headers, magnaflow X with stock muffs.
That would put the rwhp at roughly 385 with headers...It does not take much of a cam to put a Z06 over 400 rwhp whether it has headers or not...
Oh, and I did install Hi-Flow Cats to keep the exhaust somewhat environmentally correct...Maybe would have gained another 5 rwhp with out them...
Anyways...My suggestion to you, would be to go with a rear gear swap as your first mod...That way you will still have the stealthy sound and smooth idle that you are looking for...The stock Z06 cam will pull willingly well past the 6600 rpm rev limiter...
I wish I would have done the gears first...Now, the gears will be later this summer instead...
I read alot of the guys really liking the 3.90's in the Z06...
Peace...Gman
