Overlap Formula
Old Jun 7, 2005 | 05:04 PM
Hemi Killer's Avatar
14 Second Truck Club
Default Overlap Formula
What's the formula for overlap? My search button isn't working right now? Thanks.
Old Jun 7, 2005 | 05:14 PM
AnthonyR's Avatar
Int. dur + Exh. dur / 4 - LSA *2
Old Jun 7, 2005 | 06:00 PM
PREDATOR-Z's Avatar
{(Int dur+Exh dur)/2- (2xlsa)}=Degrees of overlap at .050.
Old Jun 7, 2005 | 07:19 PM
Beast96Z's Avatar
Either formula above nets the same end result.
Old Jun 8, 2005 | 07:10 AM
PREDATOR-Z's Avatar
Let us say 224/224 114lsa @ .050
so first formula (224+224/4)- (2x114)= -116
Second formula (224+224/2)- (2x114)= -4
How are these results the same??
Old Jun 8, 2005 | 11:07 AM
black_z's Avatar
The first formula should read (224+224)/4-(114)*2=-4
Old Jun 8, 2005 | 11:30 AM
So, do I want overlap to be closer to zero or further away? With my current cam I'm getting -14*, which performs great and sounds very badass. Then one of the ones I'm looking at for my LS1 (218/222-113) is -6* and the other one I'm looking at (220/224-113) is -4*. The -6* would give more lope of these two, right?
Old Jun 8, 2005 | 11:34 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
http://users3.ev1.net/~black_ops/cam...Calculator.xls
Old Jun 8, 2005 | 12:46 PM
PREDATOR-Z's Avatar
The less overlap the less lope.
(-) less lope
(+) more lope
Old Jun 8, 2005 | 02:16 PM
(-) less lope
(+) more lope
Not to sound stupid, so the -6* will lope more than the -14*, right? If so, that makes sense why I kept getting the numbers I did when changing the LSA.
Old Jun 8, 2005 | 02:23 PM
J-Rod's Avatar
Quick and Dirty Cam Calculator Spreadsheet
0.050
Intake Duration - ID 220
Exhaust Duration - ED 224
Lobe Center Angle - LCA (also known as LSA) 113
Intake Centerline - ICL 113
Intake Valve opens - IVO -3
Intake Valve closes - IVC 43
Exhaust Valve Opens - EVO 45
Exhaust Valve Closes - EVC -1
Exhaust Centerline - ECL 113
Overlap -4
0.050
Intake Duration - ID 218
Exhaust Duration - ED 222
Intake Valve opens - IVO -4
Intake Valve closes - IVC 42
Exhaust Valve Opens - EVO 44
Exhaust Valve Closes - EVC -2
Overlap -6
Neither should have much lope... The second one will have less though if any...
Old Jun 8, 2005 | 02:29 PM
Cool, thanks!
Old Jun 8, 2005 | 03:53 PM
Beast96Z's Avatar
What he said. I guess there where 2 diffrent ways of looking at the other guys formula.
Old Jun 8, 2005 | 04:03 PM
Patrick G's Avatar
LS1 Tech Administrator
Some people think that LSA determines overlap.
Overlap is amount of time the exhaust lobe and intake lobe overlap each other. LSA is only a small component of this. Duration counts much more.
For example
210/216 106LSA cam = 1 degree of overlap at .050"
220/226 110LSA cam = 3 degrees of overlap at .050"
230/236 114LSA cam = 5 degrees of overlap at .050"
So even though my LSA got 4 degrees wider in each successive cam, the overlap grew as well. LSA and overlap do not necessarily go hand in hand.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
