pics of iron block please??
Old Jun 8, 2005 | 04:00 PM
98sspullin'em's Avatar
Default pics of iron block please??
i was just wondering if in the iron block you had to have a hole drilled for your alternator to fit?? any pics would help out a ton becuase i dont think mine does have the hole if needed thanks, dwayne
Old Jun 8, 2005 | 04:12 PM
Dustin Butts's Avatar
Yes. I had to drill and tap one hole for the upper alternator bracket bolt. It was the upper front bolt. There is a boss there in the block but no hole. The middle alternator bracket bolt is not used. There is no place for it on the iron block. So you end up with two long front bolts and the one shorter side bolt. It works fine.
Old Jun 8, 2005 | 04:34 PM
yep, mine doesnt have the hole, guess ill have to try and drill it myself,
Old Jun 8, 2005 | 04:43 PM
Just take your time and go slow. Use a center punch to make a good dent in the drill spot before you start. Keep oil on the drill bit. Keep the drill good and straight. It's not too bad.
Old Jun 14, 2005 | 05:37 PM
MIGHTYMOUSE's Avatar
i never did this and havent had any problems with just two bolts holding it in
Old Jun 14, 2005 | 05:50 PM
ArcticZ28's Avatar
One of the two bolts you're talking about is the one he has to drill. The 6.0 only comes with one bolt hole where the alt. mounts. You have to drill the second hole to mount the second bolt for the alt. Mine came with it already drilled, so that made me a bit happy.
Old Jun 14, 2005 | 06:34 PM
Brains's Avatar
I've only got two bolts in my alternator as well, been fine for a couple years now..
Old Jun 14, 2005 | 07:55 PM
By two bolts you mean the one lower front bolt and the side bolt only...correct?
Old Jun 14, 2005 | 08:17 PM
yup, i drilled mine and all i have to do now is tap it, but i got the motor and tranny in and bolted up, with the help of a buddy on here (thanks again) cant wait to start her up...
shes been sittin there since sept-oct, you think that gas in the tank is bad by the way??
and thanks for the help!!!!
Old Jun 14, 2005 | 10:11 PM
Ryan K's Avatar
Pathological Modifier
No, the two are the lower inner, and the upper outer, the bolts are the same lenght about 4" long. The side one that is about 1-2" is pretty much optional.
Ryan
Old Jun 15, 2005 | 07:09 AM
Brains's Avatar
Actually, mine IS one on the front, one on the side. No problems
Old Jun 30, 2007 | 12:20 PM
yobabiesdaddy2001's Avatar
what size tap and punch?
Old Jun 30, 2007 | 12:31 PM
PREDATOR-Z's Avatar
You can but it is not necessary. I run mine with 2 bolts only on 200 shots of nitrous without an issue ever.
Old Jun 30, 2007 | 12:34 PM
did you tap yourself?
