Dropping oil pan
Old Jun 11, 2005 | 05:44 PM
1999TransamWs6's Avatar
Question Dropping oil pan
I was wondering what the easiest way to drop the oil pan was?!?!?!
Old Jun 11, 2005 | 06:04 PM
ss rally red's Avatar
What are you trying to accomplish?
Old Jun 11, 2005 | 06:15 PM
LSONE's Avatar
unbolt motor mounts, jack up engine via bellhousing and 2x4, unbolt k-member, pry it down some, pull off oil pan.
Old Jun 11, 2005 | 07:28 PM
I am doing a head and cam swap and the pan has to come down some to loosin the bolt on the pick up tube. I am trying to get the pan off so i can remove the old gasket and put the new one on.
Old Jun 11, 2005 | 07:31 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
What size cam? Since you will be in there, I recommend doing the rod bolts too if you will be spinning much over 6500 rpm.
Old Jun 11, 2005 | 07:37 PM
Ok sounds like that is what i will do because i want to spin it to about 6800-7000.
Old Jun 12, 2005 | 02:37 PM
Well i just got the pan out and it was a breeze thought it would be tough but it wasnt hard at all. Now i need to buy some rod bolts, which ones do you recommend? Also when you take the old gasket off the oil pan do you rip it off or drill out the rivets? Thanks
-Joe
Old Jun 13, 2005 | 10:23 AM
Steve Burger's Avatar
LS1TECH Sponsor
Drill the rivets and get Katech rod bolts. You will be good to go.
Old Jun 13, 2005 | 10:38 AM
blkZ28spt's Avatar
Katech, though a lot of people still run ARP as well. Important thing to have if you spin past 6500 rpm very long, IMO.
