Can you fit a 4.125 bore heads on stock 3.9 bore shortblock?
More than likely, I'll be switching to LS7 heads for my 427 when they become available. A friend of mine is planning on buying a budget stage 2 heads and a big cam for his C5. However he is now interested in bolting my heads if it would be possible.
I do know that I would need 4.130 bore head gaskets. What else other than that? The intake valves are 2.08 & exahust are 1.60.
Thanks
Thanks
Thanks for the responses. So basically you guys have put a 4.125 bore AFR heads on a short block that has 3.9 bore cylinders, Iam I correct?
Besides, how soon before you get some dyno numbers or track times?
