Cam postion sensor high error after cam swap
Old Jun 16, 2005 | 09:11 PM
777's Avatar
777
oh well. I'm going to take a gamble. I'll be swapping cams soon enough probably so I'll fix it when I'm there. This time I'll use locktite, and a torque wrench.
Old Aug 27, 2005 | 08:34 PM
99whitews6's Avatar
Alright, left my house this morning for a 35 mile drive and the same thing came up with about 7 miles left on the trip. I was logging so I noticed the code right away. P0343 and then the tach died. Car continued to run but got louder and louder for the last couple of miles. I had the car towed home and it sittings in the garage now. Whats the easiest way to see if any damage occured? OR should I just try to tighten up the cam bolts? I havent pulled anything off yet. If there has been damage done, would there be any sort of shavings or anything in the oil if I drain it?
what fun!!
Old Aug 27, 2005 | 09:42 PM
2000Hawk's Avatar
congrats on finding out the problem just in time before a major disaster happened. now i know before my swap to make sure the cam is really torqued down.
Old Aug 27, 2005 | 09:57 PM
99whitews6's Avatar
So you think theres probably no damage?
Easiest way to find out whether there is damage or not?
Old Aug 28, 2005 | 08:52 PM
GuitsBoy's Avatar
well, if the timing chain didnt slip, and the cam sprocket can easily be tightened back up against the cam, you should be fine. I dont know why it was making noise, possibly just the timing chain sprocket wobbling back and fourth. If any real damage had occoured, it would have taken the form of a blown engine. Valves would have gone through the pistons due to the timing chain coming off, or the lifter could have rolled off the cam lobes and jammed up. Ill bet youre fine, but check you might want to look at the chain, sprockets and timing cover to see if anything looks worn just to be safe. Good luck, and im glad you cought it.
Old Aug 29, 2005 | 08:13 AM
99whitews6's Avatar
Thanks Guitsboy. That makes me feel a little better. Im guessing the noise could have possibly come from the lobes hitting the bearings or something.
Old Aug 29, 2005 | 08:33 AM
GuitsBoy's Avatar
I dont think your lobes can possibly hit the bearings, otherwise you wouldnt be able to slide the cam in or out.
Old Aug 29, 2005 | 10:28 AM
bowtieman81's Avatar
The noise may be from the cam retainer bolts hitting the cam sprocket if they are backed out far enough. If thats the case its probably not good
I know its a pain, but you may want to pull your cam and take a look at the lobes to see if any damage was done to them. If you do that take a look at the cam bearings and see if they look good (you can't see much but try).
Good luck to you.
Old Aug 29, 2005 | 10:40 AM
GuitsBoy's Avatar
I still dont see how the cam lobes or the bearings could possibly be harmed when the lobes are smaller than the bearing journals. The cam would have to have walked more than a half inch and the shaft would have fallen out of the bearings and the entire engine would have jammed. So long as the engine was still running, I cant see the camshaft being damaged. Id be more worried about the sprocket wobbling around whacking into stuff and stressing the chain. But this is just my opinion. Definately would welcome anyone having valid reasons for thinking differently... plus it never hurts to check.
Old Aug 29, 2005 | 11:17 AM
Well, the reason I sugested checking the lobes of the cam was because if it walked then the lifters would have been riding off-center on the lobes. Depending on how much off-center there may have been some damage done. I would guess he is OK because the cam would have to walk a maybe 1/4 inch to really get off-center. That is just my thoughts, I have been wrong before
Old Aug 29, 2005 | 11:40 AM
GuitsBoy's Avatar
I guess you mean that if the lifter roller would be more than 1/2 off the edge of the cam, it would spin in its bore and gouge out the cam? I suppose its possible. Ive seen pics of spun lifters and the carnage it leaves behind. Not pretty. However I would think the spun lifter would sound like a coin jar in a paint mixer... Good call though, couldnt hurt to check and make sure. Maybe when you tighten the cam bolts, you could just tighten two of the bolts up first and leave the third to gauge how far it had walked. If it was only like 1/8" I wouldnt bother pulling the cam. If it was 1/4 or more, you might want to check it out. Just trying to come up with some ideas and possibly save some effort.
Old Aug 29, 2005 | 02:25 PM
  #32
99whitews6's Avatar
Thanks guys!
Old Aug 29, 2005 | 03:42 PM
  #33
robertbartsch's Avatar
WOW!
This issue happened to me. I have replaced the cam sensor twice and the crank sensor once. Last week I ripped the front cover off to check and see if my cam was sleep walking....
Nope - tight as a pup. I used a double roller chain and DID USE LOCK TIGHT AND A TORK WRENCH FOR THE cam RETAINER. - VERY IMPORTANT...
I have heard that our cams have a built-in reluctor type deal that the cam sensor uses to read the cam position Vs. #1 at TDC.
I'm sure that if I blow another cam sensor that my reluctor wheel and cam are dead (Comp Cams special grind)
Old Aug 29, 2005 | 03:47 PM
  #34
GuitsBoy's Avatar
The cam reluctor is built into the backmost bearing journal on the cam. It cant really be damaged as far as I can see. Did you happen to check both the cam bolts and the cam retainer plate bolts? The only lther thing I could see is that the cam was ground a little bit off.
Old Aug 29, 2005 | 03:53 PM
  #35
I checked the cam walk by grabbing the top sprocket and moving it back and forth - no walk here!
I checked the sprocket bolts - good and tight....
aftet 12K the double roller did not even stretch a tad - very snug!
Old Aug 29, 2005 | 03:55 PM
  #36
So the cam reluctor is built into the rear cam journal? What is a reluctor - a magnet-type deal; right?
Old Aug 2, 2006 | 12:36 PM
  #37
tweeder's Avatar
I have the same prob with the code but my tach still works, what does that mean?
Old Aug 2, 2006 | 01:25 PM
  #38
dug's Avatar
dug
I didnt use lock tite or a torq wrench. Still running strong after 30k miles
