408 rotating is on the way!!!!
Old Jun 16, 2005 | 11:26 AM
VIPER EATER's Avatar
Default 408 rotating is on the way!!!!
ok guys this is what i orderedthis week.
408 rotating with compstar forged rods, mahle pistons, and eagle crank.
mcloed street twin with steel flywheel
moser 12 bolt
head bolts
head gaskets
double roller timing chain
ls6 ported oil pump
oil pan gasket
rear cover seal
pushrods
springs
tsp ministick
cam bearings
valve stem seals
pilot bearing
02 extensions
fuel pump
and a computer tune
what kind of power do you guys think i will makethe heads will be 241 casting that i will clean up a little bit. and ill be runnin the mini stick from TSP so any ideas will be great and let me know on what you guys think
Jason
Old Jun 16, 2005 | 11:36 AM
Cal's Avatar
Cal
Well I got 431 rwhp and 398 rwtq with the TSP 235/240, which I think was the prototype for the mini-stick. I did a little home porting on my 241 heads. I'm also running through a Moser 9 inch and had a cooked clutch for the dyno. So with the 408, you should be well above that, maybe about 500 rwhp.
Old Jun 16, 2005 | 12:08 PM
JZ'sTA's Avatar
NO WAY IN HELL WILL YOU HIT 500 with those heads.
Your gonna have a nice bottom end now it's time to start working on the top end.
Your setup is gonna be like a chick with a fine *** but no tit's.
Spend the 4000 for the bigger boobies and now you have a complete package.
I would look into some AFR/TEA heads and a 90mm TB and intake. Without that I wouldn't expect much more then 450-460.
Old Jun 16, 2005 | 12:31 PM
JakeFusion's Avatar
Super Hulk Smash
rofl
Yes, and I'd get a bigger cam too. Look at the TSP Texas Giant Cam with some TEA/AFR Stage 3s, and FAST LSX90. With some 1-7/8" QTP HVMs, it'd make 550-575rwhp.
Old Jun 16, 2005 | 01:40 PM
v8maro's Avatar
Yeah, those heads will kill you. And don't buy a custom cam from whomever is assembling the motor, tell them your needs and what heads you'll be running, they will mate a cam up to it better than you can.
Old Jun 16, 2005 | 05:09 PM
well see thats why were just gonna clean the heads up so that we dont lose all our bottom end but were not gonna go wild, cause i know its not a big cam for a stroker. but the guy that gave us the idea said why port the sh*t out of your heads and lose bottom end when you'll have the bottle to carry you through the top. thats why were not going very big on the cam right now and crazy on the heads. i bought a set of 853's from a friend of mine here in town and when the motor is back up and running im gonna start porting the sh*t out of those heads and then when i have the money to upgrade in springs and im able to afford the cam, then we'll go ahead and put the ported heads and the giant in there. thanks for the quick replies guys and keep them coming
Thanks Jason
Old Jun 17, 2005 | 02:11 AM
JZ'sTA's Avatar
The reason why you go big on the heads is because of the crank you have. Whoever gave you this info need to do a little more research.
I bet my *** you will run faster with a great set of heads then you will a avarage set of heads.
(As long as your 60 ft's are the same, and same weather etc.)
If this wasn't the case we would all save mega cash on the heads.
