p to v clearance
Old 06-17-2005, 09:17 PM
JohnsTA's Avatar
Default p to v clearance
do i need to check it if i have relifed pistons? i have a g5x2 type (comp) cam, stock length pushrods, about .035 off the heads and new pistons with reliefs. stock gaskets too. should i be able to just put it all together, or should i checked the clearances. you would think with the pistons it should be ok, right?
Old 06-18-2005, 03:02 PM
Dustin Butts's Avatar
You should ALWAYS check it. ALWAYS. Did you degree the cam when you put it in? If you're off a few degrees, retarded or advanced, then you'll be putting the exhaust or intake valves respectively a little closer to the piston.
I just put a new cam in my car and installed it straight up and it was off 4 degrees retarded. Fairly new timing chain and gear...Cloyes hex-adjust. Check..check..check...
If you have an even older timing set you can be off more than that.
Old 06-18-2005, 03:05 PM
Beast96Z's Avatar
If the cam wasn't cut wrong, then you shouldn't have a problem. The only way to check though is to degree the cam in. P/V is easy to check and personally, I'd do it just for the piece of mind. I degreed and clayed mine.
Old 06-18-2005, 03:08 PM
PREDATOR-Z's Avatar
I agree, no matter how much you're sure it fits, always degree your cam as stated above.
