cheapest shortblock w/ forged internals
cyclepunk@gmail.com
also, small shops dont need to charge as much $$ for the same work, and IMO each package gets more "personal" attention to detail.
I will be the first to call BS.
1200-1500 my ***. pistons are 580, rods are at least 400, rings are 180, main berrings, cam berrings etc parts alone cost nearly 1200 dollars.
So you going to do all the machine work, and assembly the motor foe little to no money at all?
Out of house machine work is normally around a 1000 bucks alone and in most cases 1400 or so for machine work plus assembly.
BTW you can find mahle pistons WITH rings for 509 right on TSP's website.
Or if funds do not allow, find yourself a certified used block out of a wreck and use that (that is what I did).
