What rockers and springs to get?
#42
Originally Posted by bigdsz
Dikit, forget the smoke and mirrors, the stock rockers with their light mass are more than satisfactory for 99% of the applications. I has been proven time and time again the heavier rockers have more inertia and are more prone to valve float. Also if you want a cam with more lift and duration buy a bigger cam for $350 instead of rockers for $700.
why run a bigger cam, when a smaller cam with the right parts will do better??? here's a prime example. comp cams 220/224 .581/.581 115 LSA with the vinci/crane 1.7 accelerated lift rockers vs the vinci 055 216/224 .551/.551 (1.7) 113 LSA with vinci/crane 1.8 accelerated lift rockers (bringing lift to .589/.589)
#43
Originally Posted by Mark Campbell
FWIW, using the Crane spring seat locator #144460-16 causes the installed height on most LS1's to be 1.760" (it is .040" thick) and results in 126# of seat pressure.
#44
here's my dyno of swapping from the stock rockers to the vinci/crane 1.8 accelerated lift rockers and dual springs. and this on stock tune as well.
dyno 9 before
dyno 11 500 miles later
dyno 14 10 months later
dyno 9 before
#45
http://stealthram.com/reddogplan.htm here's the CHP article on the 5.3L truck they did the vinci/crane 1.8 accelerated lift rockers and springs on as well. now the article only pointed out the peak differences of 20 rwhp and 9.6 rwtq. but look at 3300 rpms in the torque tables. right there was a 23.4 lbs-ft of torque gain. and this was on a 5.3L motor with stock cam and heads to boot.
#46
some more nifty reading right off vinci's site on the tech and tuning page. http://www.vincihighperformance.com/...20PAGE%20.HTML talks about how the rockers work. titled, More On Why Our Unique New “Quick-Liftä” Rocker Arm Geometry Makes More HP!
#47
Originally Posted by mrr23
you do not need taller valve covers. just need to grind some on the inside to clearance for them.
