Replacing Timing Cover Gasket question?
Old Jun 18, 2005 | 10:23 PM
dbhajek's Avatar
Default Replacing Timing Cover Gasket question?
Hi all
Is it possible to replace your timing cover gasket without removing your crank pulley?
I was thinking I could remove the waterpump, of coarse, and then just remove all the bolts on the cover, slide out the gasket, and slip the new one in.
Thanks
Old Jun 19, 2005 | 12:03 AM
felton316's Avatar
Yes, its do-able.
Old Jun 19, 2005 | 01:20 AM
CAT3's Avatar
Restricted User
Be very careful so you dont mess up the seal! Also, be sure to seal the bottom corners with some RTV. Good luck.
Charlie
Old Jun 19, 2005 | 10:04 AM
WILWAXU's Avatar
Normally of you have a leak in that area it's the front seal. Not the cover gasket.
Old Jun 19, 2005 | 10:12 AM
IbadZO6's Avatar
A friends of mine changed his that way with no issues...just kind of a tight fit
Old Jun 19, 2005 | 10:13 AM
'02 SLP#686's Avatar
True that!
Old Jun 19, 2005 | 10:38 AM
VSGLS1's Avatar
Unless the cover was off recently and not aligned with the pan correctly or the bottom was not RTV'd.
Old Jun 19, 2005 | 05:41 PM
OWENMUSTANG's Avatar
agree! just about as foolproof as this can get...
