asa and ls6 heads
Old Jun 24, 2005 | 12:02 AM
Magnet's Avatar
Default asa and ls6 heads
i am plannign on running the ASA cam with stg 2 ls6 heads from patriot perf. alogn with the usual lid, pacesetter LT's adn true duals, ls6 intake what kind of power should i be making? and what other boltons should i concider?
Old Jun 24, 2005 | 12:24 AM
technical's Avatar
Pulley and ported throttle body are a nice complement to that combo.
Old Jun 24, 2005 | 12:31 AM
Magnet's Avatar
what kinda of difference would the pulley and tb make horsepower wise? im pretty new to this stuff dont kn ow much
Old Jun 24, 2005 | 01:01 AM
Casperws6's Avatar
great cam to run . . . running that same cam in my car except with out the heads. ported t/b and pulley should net you some 10rwhp at least. good luck
Old Jun 24, 2005 | 01:08 AM
Magnet's Avatar
so what total hp ya think?over 400 right? what do you think 420 maybe
Old Jun 24, 2005 | 09:27 AM
jmm98LS1's Avatar
Without the heads, I would imagine that you'd be around 390-400 with ported tb, intake, pulley and a good tune. Throw on the heads and I bet you'll put down a pretty good number.
Old Jun 24, 2005 | 09:31 AM
cyphur's Avatar
keep in mind that the "LS6" style heads from patriot aren't true LS6 heads and will not perform as well as ported true 243-casting LS6 heads. Keep that in mind. If you want some really kickass heads for ~1500, look into TEA's 5.3 Rev2 heads. Those kick some major ***.
Old Jun 24, 2005 | 09:38 AM
777's Avatar
777
What about PRC's? Do you have anything against them?
Old Jun 24, 2005 | 11:26 AM
Magnet's Avatar
where can i find the TEA's? i looked at the sponsor links....where are they sold? and also what if i got true ls6 heads and got the stage two ported?
Old Jun 24, 2005 | 12:42 PM
xfactor_pitbulls's Avatar
Cyphur, dont make people think you cant make good power with those heads. Keep in mind that Patriot isnt exactly cutting edge with their cnc technique. Basically they just remove material and open up the runners. The actual 317/243 castings are so close that you can expect comparable numbers out of each considering the same cnc program is run on each. Combustion chamber shape is slightly different, I dont know better or worse, but I do know their shape has been effect. The next set of heads I do will be blank LS6 style heads from Patriot. I did a set for a customer about a month ago and they went 318 at .600 and 206 at .300. With a less agressive port job than alot of more knowledgeable people do. 2.08/1.60, but none the less its a great casting. Just take that bare casting and send it to TEA.
Brandon
Old Jun 24, 2005 | 10:37 PM
Magnet's Avatar
anyone knwo where i can findthe tea heads?
Old Jun 25, 2005 | 05:47 AM
GuitsBoy's Avatar
http://www.totalengineairflow.com/
Old Jun 25, 2005 | 08:57 PM
a9x_hatch's Avatar
for all thoughs putting sh#t on patriot heads i would like to show you the flow results i got out of there ls6 style stage 2 heads we did a flow test first and got 308cfm@.600 (about average for these heads we wernt game to test them to .650 because of some of the issues with these heads) then the heads had a good hand finish and clean up and all the assembly was checked and came out 100% fine (which cost $150) so we then through the heads on for another go and here are the results
lift intake exhaust
.100'' 77cfm 68cfm
.200'' 148cfm 125cfm
.300'' 219cfm 176cfm
.400'' 264cfm 218cfm
.500'' 304cfm 237cfm
.550'' 315cfm 242cfm
.600'' 325cfm 246cfm
.650'' 332cfm 249cfm
and this was done on a 232cc intake runner there pretty good flow numbers if you ask me
