What the hell is this whine???
Old Jun 24, 2005 | 10:41 PM
getlifted's Avatar
Bad Seller Alert
Default What the hell is this whine???
Just put a ls1 motor in my car. Fired it up. Runs fine but there is a whine that sounds like a turbo. It is not from the intake, lid,airbox,tb,etc. It sounds like its coming from the back of the motor. All sensors and everything is hooked up. As you rev the car, the whine keeps up with the motor. Have no idea what this is. Any help is appreciated.
Old Jun 25, 2005 | 04:17 AM
Torquem's Avatar
I have never taken a close look at the manual tranny's in our cars...but do they have some type of flywheel cover? I have bent flywheel covers on other vehicles and when the flywheel hits it it sounds like a blower whine. And it wont necessarily do it all the time. It will also go up and down with the rev's.
Old Jun 25, 2005 | 05:25 AM
eallanboggs's Avatar
Whine, squeal, whirr. Those type of sounds are usually associated with a bad bearing, but you need to isolate the area where the sound is coming from using a mechanics stethoscope at idle speed. Are you sure it's not something scraping on the inside of the bellhousing (metal against metal)? Whether it is in the bellhousing or internal to the motor itself this is NOT good.
