tapping sound
Old Jun 27, 2005 | 09:20 PM
hardtopz28's Avatar
Default tapping sound
When I start my car it makes a tapping sound like a lifter or something it started doing this a bout a week after I changed the oil the oil is mobil 1 5w30 it does this untill it is warm then it goes away my car is an 02 z28 any info will be greatly appreciated
Old Jun 27, 2005 | 11:24 PM
EugThinks's Avatar
This is secondhand information, so don't take my word on it... my friend's 95 Miata used to do the same thing. He said it was a common problem on the Miata forums, and their standard solution was to use 10w oil instead of 5w. Hopefully someone else can provide more information... good luck!
Edit: The Miata guys identified the problem as "lifter tick", maybe that will help you find more information.
Old Jun 28, 2005 | 01:23 AM
TMOWS6's Avatar
Piston Slap, its a common problem among LS1 f-bodys, its never been proven to cause damage to LS1's. you can go to www.pistonslap.com for more info about it.
Old Jun 28, 2005 | 07:17 AM
WS6FirebirdTA00's Avatar
piston slap most likely, when its cold there are pretty loose tolerances, when everything heats up and expands correctly it tightens up and the noise goes away
Old Jun 28, 2005 | 07:47 AM
RevGTO's Avatar
Pontiacerator
It may be piston slap or lifter noise - piston slap is deeper sound, almost like a knock; lifter noise lighter, more like tapping. My LS1 has mild piston slap on cold starts below 45*; my wife's 3.4 V6 has lifter noise for the first few minutes after cold starts no matter what the outside temps. No problems because of it after 105,000k.
Old Jun 28, 2005 | 08:24 AM
777's Avatar
777
If it goes away withing a few minutes I'd say it's piston slap. If it doesn't I'd say it's the lifters.
Old Jun 28, 2005 | 10:50 AM
Joel_SS's Avatar
Another Vote for piston slap.. Very common problem, she people see it as a serious problem and some do not.
Old Jun 28, 2005 | 11:40 AM
hardtopz28's Avatar
I appreciate all the answers i think its piston slap as long is dont affect the car im not going to worry about it thanks for all the replys
