Baddest Heads Cam combo...
Originally Posted by SStrokerAce
Well the baddest set of heads you probably can't afford... meaning a set of heads prepped to the level a Super Stock car has, but without rules. You would probably **** your pants if you saw prices on that.
Bret
Bret
Originally Posted by blkZ28spt
I wouldn't say you are way off that number. His range started at 450, and you are making 441 and have yet to put an underdrive pulley on. You may be at the low end of the range (with pulley), but in it nonetheless.
JBGRAYTA, I'll be dynoing my combo in a couple of weeks
I'll pm you the results if you like
Christopher's Onyx Black 2001 SLP T/A Firehawk M6 #89
Bilsteins, Chrome Rims, Deck Mat, Birth Certificate, Portfolio
PERFORMANCE: Jung's S2 Heads stock CR | TSP 237/242 MS3 | '03 Viper Tranny | F.A.S.T. LSX 90mm Intake Manifold | Kooks 1 7/8”, 3” Y with Corsa | Spec S3 Kevlar Clutch | SLP Hi-Flow Radiator | Meziere EWP 160* | LPE 3 1/2" Aluminum Driveshaft | F.A.S.T. 90 mm TB | De-screened MAF | TSP Clear Lid-K&N | ASP Crank Pulley | LS6 Ported Oil Pump | Rollmaster Double-Roller Timing Chain | SLP Bellows | NGK Plugs-MSD'S | Harlan's Shiftlight | FRA | TBB | tuned by Me | Crane Valvetrain with PP .650 lift springs | Hotchkis SFC's & STB | Mac Rear-End Cover | Stock Hurst with UMI Short Stick | SLP Reverse Logic Module | New '04 LS1 engine at 48K mi | Brembo Slotted and Cross-drilled Rotors with Red Calipers.
COSMETIC: Granatelli 200 mph White Gauges, Custom Front Air Dam, Custom Firehawk Fuel Rail Covers, Custom Firehawk Headrest Embroidery, Custom Carbon Fiber Interior, Custom Red Leather Interior, Custom Red Carpet, Custom Red Tubing for Engine Bay, Mallory Billet Polished Aluminum Interior, Pioneer 10" Stealth Box, Clear Corner Lenses, Trans Am Valve Stems.
Brenda's 2001 Racing Red WS6 A4
SLP Loudmouth Exhaust, SLP Lid-K&N, Jantzer S2 TB, Bilstein Shocks, Eibach Lowering Springs, UMI SFC'S/STB, Brembo Slotted/Cross Drilled Rotors with Red Calipers, Clear Corner Lenses, Trans Am Valve Stems.
Originally Posted by pdd
o really? im way off that number
Originally Posted by 777
AFR's and a G5X4 or custom for all out max power crappy driveabilty.
For max power, go big heads, solid roller. period
I don't I just figured it would be since it's over a 240 duration .6XX lift cam. Or the fact that LG said that it's not a daily driver cam. Just a few little things that lead me to believe it won't drive all that well. I have no seat time in one though so your word is better than mine. I still see no reason to be so hostile in correcting a simple mistake.
Side note though. Driveability varies from person to person. Some people think it's terrible driveability if it surges at 1200rpms. Some can live with giving it gas at stop lights so it won't stall.
Haha, threads like these make me laugh.
To the original poster: THERE ISN'T A BADDEST H/C COMBO!!!!
Example:
SMOKIN01TA on this board dynoed 440 cam only
pdd dynoed 440 with the a good sized cam and the baddest heads on the market.
H/C combo's are not predictable, meaning there cannot be an absolute "best" setup.
Example:
pdd has some serious issues and is skewing the data. Even though a respectable tuner did the tuning something is not right. In no scenario should a tuned (even untuned most likely) f-14 be stalling anytime, yet alone every light. Something is either wrong with tune or something about his setup. His numbers have been dissapointing ever since the begining. I really hope you get these issues worked out because your car should make unreal numbers.
sorry hehe, but no the driveability is great and little surging. It never stalled out either.
Originally Posted by JBGRAYTA
on pump gas, stock 346, no nitrous. What is it? Driveability is not an issue, nor gas mileage, bucking, surging, etc. Just times in the quarter. A 4400 stall will be matched up to this as well(to have SOME streetablity, as this would be a weekend and track car). How about a G5X3 and a set of AFRs? Or the GMPP LS6 heads and Grand Am cup Cam(thats the one I like). Or maybe a sleeper, like a smaller FM cam and a nice set of heads(a proven combo). I know of the cam-only setups, but what about this?
Fast 90 Intake
TRex
LS7 heads (chk p to v clearance)
Kooks
elec. H20 pump
spin it to 7500
