382/383 stroker? Compression?
Old Jun 29, 2005 | 10:26 PM
shaulinmathvader's Avatar
Default 382/383 stroker? Compression?
How much power would a 382 stroker ls1 with maybe at least a 630 lift make?hoping to make 500+ horsepower. what problems would arise.
what would be the maximum compression ratio that I could have with a 383 stroked and fully cammed in order to keep it streetable
Old Jun 29, 2005 | 10:32 PM
Lithium's Avatar
SSU's Drunk Typing Whore
try the LS1-LS6 Internal Engine forum. You will get more responses there.
Old Jun 30, 2005 | 02:58 AM
DONAIMIAN's Avatar
Its gona be hard to get the amount of power out of a stroker, with a big bore motor on the other hand itll be easier because you could run a stage 3 head (opening up the chamber more and unshrouding the valves, and youd gain head flow combustion efficency and a list of other things.
Old Jun 30, 2005 | 03:28 AM
kumar75150's Avatar
u could get right at 500rwhp with all the right bolt-ons
go upto 11.5:1 or so on compression
kumar75150's Avatar
btw, the highest mine ever made was 508 with the belt and 517 without
.635 lift cam
Old Jun 30, 2005 | 06:36 AM
SAM98WS6's Avatar
You could do it with 11:1...I made 480rwhp with only .595 and billet flywheel, steel driveshaft and moser 4.11. A good stage 2 head like rapid or AFR 225 will do it. Or you could do an LS2 and push 550.
Old Jun 30, 2005 | 06:37 AM
PREDATOR-Z's Avatar
If stock cubes can go to 480+ rwhp, a 383 will go over 500.
It is all in the heads and cam combo (high flow intake/TB too). That motor is gonna want to move some air so at least 2.05 intake valves needed. 1.6 exht.
But do not get wrapped up in peak HPs. Under the curve power is where it will shine.
