HELP, i cannot figure this out help diagnose
Old Jul 1, 2005 | 05:27 PM
vodas00ss's Avatar
Default HELP, i cannot figure this out help diagnose
This dosent have to do with my ls1 but my truck is going to kill me if i cant fix it.
Its a 98 chevy 5.7 litre . While driving the truck all of the sudden it will shut off. You can turn the key and it will start right back up. Also when you floor it when it reaches the higher rmps it will surge like its misfiring.
Ive replaced the cam sensor, crank sensor tested good, timing has been set at the dealer. new plugs, wires , cap ,rotor. Truck idles great. WTF???
Maybe the tranny? Any suggestions would be greatly appreciated.
Old Jul 1, 2005 | 05:38 PM
Seagraves#85's Avatar
Sounds like an ignition coil going or already bad.
Old Jul 1, 2005 | 10:16 PM
zamboxl's Avatar
it could also be a bad ground are ur gages acting funny???
Old Jul 2, 2005 | 06:44 AM
Dustin Butts's Avatar
Check fuel pressure....
Old Jul 4, 2005 | 01:26 PM
vodas00ss's Avatar
I just replaced the fuel pump, and filter. And tired a new coil on it as well.
Old Jul 4, 2005 | 04:00 PM
Let us know what worked for you. Ive troubleshot this problem many times and 90% of the time its a bad ignition coil.
Old Jul 5, 2005 | 03:22 PM
ss00's Avatar
Pull out the computer, and tap on it with a screwdriver handle with the engine running. If the truck dies, there is a faulty solder trace or component in the computer.
