thunder racing CheaTR cam installed
sup Scoob.nice cam choice.
The V3 is one I keep considering for my 6.0, but I live at high elevation, so that would make it lope more than at sea level. The V3 has 2.5 degrees more overlap than the V2, and that also increases lope. But my extra 0.3L will slightly reduce lope.
Also, the CheaTRs have a really early exhaust opening, which Comp says will add some sound. Plus the V3's late intake closing, which is good for high rpm, is not so good with the lower dynamic compression of higher elevation. But I'm looking at ported and milled 5.3 heads with 2.00 / 1.55" valves, and LS2 / LQ9 flat top pistons. That gives 12.1:1 static, but corrected to 4,500', equals 11.2:1 at sea level.
It's going in a lightweight, over-geared Fiero. I really need a stealthy sound, and there are no LTs for it, while the '00 F-car LS1 manifolds fit really well. Those are ported and polished also.
