thunder racing CheaTR cam installed
Old Jul 3, 2005 | 04:00 PM
Scoobie's Avatar
Default thunder racing CheaTR cam installed
Well the cam is in and here is how she goes.
1. There is definetly more power throughout the entire power band..from a dig, almost a bog, the power snaps back to life quick and revs fast pulling you back into the seat much more then before. And much better then my two previous cams. Power is down low as much as it is up high. Power gain, CHECK
2. Stealth, The cam is choppy with long tubes, off road ypipe and magnaflow. After idling for more then 5 seconds, the cam finds a slight lope..more of a chop then a lope, its quick, not like a 112 or a 114 cam..its faster, but no doubt there is a cam in the car. Ill put the cats on it tomorrow and see what kind of difference that makes. Stealth,
3. Drivability, No difference what so ever...drives exactly the same, just pulls harder! I noticed an increase in the "gas" smell but there is no noticeable sewing machine noise like with the TR224 112 i had before in my old car. No bucking, no surging and i have not tuned her yet. Daily driver, CHECK
4. Over all impressions, it doesnt seem that the power band changed at all, there is just more power everywhere. My TR 224 didnt drive as nice as this cam and had a slightly slower and more pronounced lope. With a cut out, this thing would sound pretty mean. Stealth is out the door with the ORP and LT's, its not noticeable though unless you know what a cam is. Drivablity is awesome, unchanged from stock. It doesnt have the OMG turbo feeling at 4k that my Equalizer cam had but its smooth and pulls nicely, and i didnt sacrafice any low end at all. Ill race you from 6th gear!
Old Jul 3, 2005 | 04:15 PM
superchannelkev's Avatar
good deal, glad to hear ur happy with it..
Old Jul 3, 2005 | 04:31 PM
greatskiiiier's Avatar
whats the gas mileage change from the TR 224, and what was the TR224 change from stock?
Old Jul 3, 2005 | 04:38 PM
gomer's Avatar
Did you use the 918's with this cam? If so, did you use the stock retainers? Also, do you think it will be ok for 20k or so miles on the 918's?
Old Jul 3, 2005 | 05:09 PM
davered00ss's Avatar
Moderator
What are the spec's on that cam?
Old Jul 3, 2005 | 05:27 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
214/230 .601/.578 117 LSA
Old Jul 3, 2005 | 09:04 PM
Scoobie's Avatar
have only put a few miles on it so far, im about on E though so ill fill up, and let you know
Yes, i used 918 springs with titanium retainers. I doubt it will make it 3K miles with me because i drive about 1K miles a month and something tells me heads with dual springs willl be on her by summers end. As far as spring life, id probably change them at 10K if not. I dont drive much, but i drive kind of hard.
My specs were 214.9/ 231.9 .599/.577 116.9 LSA
Im off to drive it more now, have to go to work, ill let you guys know more after this coiming weekend when i can really get on her.
Old Jul 3, 2005 | 09:54 PM
JZ'sTA's Avatar
Scoobie.
Please dont take this offensive, just asking some questions as to my idea of the cheater cam.
First I thought this cam was more for the cars running stock or close to stock exhaust.
It was intended to sound like a stock cam through the stock exhaust but pull much harder. With this being said why did you choose the cheater cam with LT's and full aftermarket exhaust? I believe a different grind with a closer split would have gained you more power, been just as driveable and if ground on that 117LSA would still be very similar as far as stealthly.
I believe with your current mods maybe a 224/228 581/588 116/117LSA would have been a better choice for overall power and would have still given very good street manners and ideal quality.
Please explain if you dont mind, and correct my theorys if they are wrong.
Thanks
Old Jul 3, 2005 | 10:18 PM
Scoobie's Avatar
I believe your theory is correct. I ordered this Camshaft before i ordered the headers. I bought dynatech headers specifically to be able to swap on/off the high flow cat converters. Also, i just recently sold the Car in my sig and was running a Big Equalizer cam. I wanted something stealthy because this car is a Limited Edition 35th anniversary car. Ive only got 11K miles on it, i hardly drive it and didnt want to give up any comfort or drivability. I know i could have gotten more power, but to really sum it up. I wanted to do a stealth cam, with all the bolt ons. Keep the exhaust as quiet as possible with no surging or bucking. This isnt a max effort drag car like my 1LE was. I just wanted something fun for the street. Ill be doing heads as soon as i get some new tires and a strong clutch. Lastly, my wife drives the car and she hated the big EQ cam and hardly ever drove it when i had the TR 224 cam. Thanks for your questions. Ill put her on the dyno soon and we'll see how she does.
Old Jul 3, 2005 | 10:43 PM
JZ'sTA's Avatar
Cool, Thanks for the reply.
Makes more since now.
I have a 220/224 on a 117 in a locals car even though I wont ever admit that again.
HAHAHAH
You cant tell its there. He has LT's and exhaust and is using Z06 springs.
Cam is great with his 3500 stall as the combo really works well.
Anyways thanks again for the reply, and good luck with your dyno results.
Old Jul 5, 2005 | 06:07 PM
TT_Vert's Avatar
how much vacuum are u guys w/ the cheater cam pulling at idle? and at what rpM?
Dave
Old May 9, 2007 | 12:19 PM
2002TAWS6Pontiac's Avatar
How much RWHP did you gain using the CheaTR cam? anyone?
Old May 9, 2007 | 12:59 PM
Patrick G's Avatar
LS1 Tech Administrator
Holy thread from the dead. 2005?
FWIW, most people gain 35-40 rwhp with stock manifolds and 40-45 with headers...all with excellent drivability!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 9, 2007 | 02:15 PM
transamfreak01's Avatar
haha thats what i was thinkin too. thread from 2 years ago, damn
Old Jul 2, 2008 | 08:14 PM
Blk_Ws6's Avatar
Unhappy
How much diffrent in hp is the ls6 cam vs. cheatr cam ?
P.S Use with stock manifolds.
Old Jul 2, 2008 | 09:31 PM
RE AND CHERYL's Avatar
LS6 cam would be a waste of time to install as gains would be minimal. I would assume the CheaTR cam with LT and related bolt ons would dyno around 375 ish RWHP. I have a Stealth II and got challanged to more than a few races because others though the car was stock with exhaust.
Re'
Old Jul 2, 2008 | 09:52 PM
Blk_Ws6's Avatar
Red face
Re'
How much louder is your car with the catted headers over stock?
Old Jul 4, 2008 | 02:08 AM
PONTIAC SLP's Avatar
i installed the cheater cam before but i did't like it even so i swapped to the MS4 , some videos with cheater , those videos without tune i did't tuned the car with that small cam
LM Cat back + cheater + 4.10
http://www.youtube.com/watch?v=wLyHMfDoXdY
launching same mods
http://www.youtube.com/watch?v=5o7bIgAOpgs
Old Aug 17, 2009 | 04:01 PM
kinglt-1's Avatar
^Sounds decent to me for a driver! What kind of power did it make?
Old Aug 17, 2009 | 04:22 PM
Gaunt's Avatar
Why the hell is this thread back from the dead.
