question re: valve train noises that dont seem normal.
Old Jul 10, 2005 | 10:49 AM
  #41
TT_Vert's Avatar
i dont have a magnetic plug. Every rocker does the same thing though>
Dave
Old Jul 10, 2005 | 01:18 PM
  #42
TT_Vert's Avatar
well i put my buddies rockers on today and they did the same thing. I noticed his had the same amount of play. I have one question about preload and pushrod play. I used a dial on a few valves and had about .100" preload. However i noticed this AM when i put the other rockers on and torqued them to 22 ft/lbs, the pushrod would rotate a tad. Not alot and with quite a bit of effort required, is this normal?
Also, again the noise didnt start right away. It didnt occur until oil temp was about 95 deg or so then it gradually started to get a bit louder till it hit its normal sound. I noticed even though the oil pressure was 50 psi it was occuring. I think its safe to say its not an oil pressure problem.
Im out of ideas now..
Dave
Old Jul 10, 2005 | 01:50 PM
  #43
Patrick G's Avatar
LS1 Tech Administrator
Must be a bearing problem then. Often, they will be quiet until the temp rises high enough to change the clearances.
Old Jul 10, 2005 | 01:54 PM
  #44
TT_Vert's Avatar
i figured if it was a bearing problem, killing a cylinder would change the pitch some. I killed all 8 the pitch didnt change a bit.
Dave
Old Jul 10, 2005 | 04:43 PM
  #45
TT_Vert's Avatar
Another little update: i put some 20w-50 in and the noise didnt change at all.
Old Jul 10, 2005 | 06:52 PM
  #46
Steve454's Avatar
Dave
Dave is it possible that the rocker boss could be cracked and allowing a rocker arm to flex under load and heat expansion? I had a similar noise years ago on some SBC heads where the rocker stud boss was cracked and causing noise. Any chance you can put your old heads back on to see if the noise is still there? Based upon all the rod knocks I've heard in the past 20+ years, I don't think that you have a rod knock; especially since you killed each cylinder and didn't notice a change. I'm not Mr Goodwrench though lol
Old Jul 10, 2005 | 06:59 PM
  #47
TT_Vert's Avatar
i would be able to visually ID a cracked boss id assume? I can check that certainly but it seems to be happening on both sides so i dont know if that is the problem. I could put the oem heads back on and that very well may be the next step. Not really what i wanted to do but its an option.
Dave
Old Jul 10, 2005 | 07:19 PM
  #48
Steve454's Avatar
Dave
Actually you may not be able to see any cracks.......would likely need to be zyglo'd (sp?) I had to pull my old SBC heads and have them magnafluxed to find the crack.
I think I would put the oem heads back on before considering pulling the pan to change the bearings. You've done all the requisite steps in determining rod knocks/wrist pins: killing the cylinder, changing oil weight, etc and it really sounds like it's an upper engine problem. If the noise is still there with the stock heads, you can eliminate the heads, rockers (since you tried your buddy's rockers), valves, pushrods (you tried new ones with no luck), springs, etc. You'd be left with the cam, lifters and or rod bearings. BUT if the noise goes away..........
I'm really considering updating my heads and using the same cam but I'm waiting to find out the results of your dilemma before taking the plunge.
Old Jul 10, 2005 | 07:22 PM
  #49
TT_Vert's Avatar
yeah i think you are right, im just so sick of pulling heads already.
dave
Old Jul 10, 2005 | 09:05 PM
  #50
TT_Vert's Avatar
. I pulled the front cover off, checked the back of the car gear for any contact and that cam retainer plate/seal for wear and both looked fine. Does anyone know how the lifters receive their oil/ It seems that front cam retainer just seals a passage from one bank lifter oiling passage to the other.
Dave
Old Jul 11, 2005 | 10:51 AM
  #51
Armageddon's Avatar
...with cheese.
I feel ya on the heads thing man... mine have come off 5 times lately. I'm so sick of it.
Old Jul 11, 2005 | 12:23 PM
  #52
TT_Vert's Avatar
yes very. i cant even put my stock heads back on w/o swapping the springs over due to coil bind. SO if the noise does occur, it dosent eliminate the springs as a posibility
dave
Old Jul 11, 2005 | 12:36 PM
  #53
AdamSS's Avatar
If you have some $$$ in your budget, get some aftermarket rockers (HS or Yella-Terra) and see if it helps...To me it really sounds like a rocker problem...
Just make sure you check the geometry with the new setup...
Old Jul 11, 2005 | 12:41 PM
  #54
TT_Vert's Avatar
i really dont have the money but if i could be certain it was the problem, they would be in there. I put some other OEM rockers in and they made the same sound. What id like to do is find someone to let me borrow some for an hour to test that theory but i know that'll never happen.
Dave
Old Jul 11, 2005 | 03:25 PM
  #55
TT_Vert's Avatar
update #99,233. I replaced the cam retaining plate just to make sure enough oil was getting to the lifters and it didnt do a thing. I decided to brake torque it and the noise seems to go away. The problem is its 6 spd and the noise usually occurs around 2500ish. the ebrake cant hold the car really so its hard to tell for sure but im pretty certain the noise is completely gone when i brake torqued it. Which would make sense since i dont seem to hear it WOT next to a wall either. It'll come back the second i let off the gas though.
Dave
Old Jul 11, 2005 | 03:38 PM
  #56
Patrick G's Avatar
Are you still running AIR tubes? If so, block off the tubes and recheck.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 11, 2005 | 03:48 PM
  #57
TT_Vert's Avatar
nope no air tubes. they are blocked off. YOu think and exhaust leak would go away when brake torquing?
dave
Old Jul 11, 2005 | 03:53 PM
  #58
Patrick G's Avatar
I was just thinking about your comment. You said the clattering went away at when brake torqued and at WOT but came back at decel. I'm just reaching here, but I'm trying to look for something...anything!
Old Jul 11, 2005 | 03:56 PM
  #59
TT_Vert's Avatar
any help appreciated. I figured an exhaust leak would get louder the more load?
D
ave
Old Jul 11, 2005 | 04:03 PM
  #60
Patrick G's Avatar
An exhaust leak might get louder at WOT, but what about the PCV system? When messed up, they can get louder at decel and can magnify valvetrain noise. Think of everything that happens only at high vacuum signals. That might lead you closer to your problem.
