Part number of camshaft sprocket??
Old Jul 8, 2005 | 03:01 PM
T/A rocker's Avatar
Default Part number of camshaft sprocket??
Here's the deal my dealer ordered me a camshaft sprocket for my '98 T/A LS1. Got the part in and it is GM part # 12576407 .
It LOOKS like the camshaft sprocket for the new LS2 engine - it has a raised semi-circular part (hard to describe) which looks like it is made for the newer motor with the cam sensor on the front of the engine ?
I looked up the sprocket number on GM partsdirect, and it says the proper number is 12552953.
Called the dealer and they say that part # 12552953 has been replaced by #12576407.
Can anyone confirm this?
Need to know if this sprocket will work on the LS1 or not, would be nice to know before i get the motor torn down for the cam install !
Attached Thumbnails Part number of camshaft sprocket??-gearfront.jpg   Part number of camshaft sprocket??-gearback.jpg
Old Jul 9, 2005 | 12:00 AM
T/A rocker's Avatar
I added a pic of the sprocket p/n 12576407
maybe that will help describe what I've got here
Old Jul 9, 2005 | 12:15 AM
2xLS1's Avatar
Enter the old number on gmpartsdirect then add it to your basket. You will see that it changes to the new number. The dealers computer does the same thing. Many times when GM releases a new part that will work on older applications, they discontinue the old part. Just like the new waterpumps with the new T-stat housings. That's all you can buy from GM now.
Old Jul 9, 2005 | 12:21 AM
T/A rocker's Avatar
Yep, I tried that and it does change to the new number, so I assume the new gear will, indeed work. Just wanted to make sure. BTW, it's more expensive than the old gear, so another great reason they only sell the new one!
Old Apr 20, 2010 | 04:07 PM
Orbit Orange's Avatar
Question Digging this one back up for an answer
Sorry about bringing this old post back from the dead but I'm wanting to know if the 1X crankshaft sprocket (for LS2's) will work on my LS1 engine in my GTO. I also ordered the part (same as the picture above) and got the updated sprocket. Any help advice is greatly appreciated. Thanks.
Old Apr 20, 2010 | 04:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yes, the raised cam gear works on LS1's...no problems.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 20, 2010 | 06:24 PM
Thank you! Thought I might have to get an LS1 specific one but glad to hear it works.
