first dyno after cam install. Time to shoot myself, or wait?
here is the rwhp #s of the first run
332 rwhp, with the converter UNlocked with stock tunning!!
I'm praying that LS6 intake and TB will help give me some more power!
should I start to worry?
any help or advice would be apprecaited
oh, the cam is a 228/224 114 .588 .581
thanks in advance
Alex
Rob
I thought I had crappy dyno figures. I got the Yank3000 too, but stock engine, just FLPs (with cats), cutout, and FTRA/lid, and I was 325rwhp or so (unlocked). 332 with a big nasty cam is H U R T I N G.
Dope
Dope
I'm glad to hear that the cam is in and running. How did you get it to idle on stock tuning in an A4? Do you know what kind of timing and a/f ratio you had on that pull? You have a ton of power to gain!
You're installing an LS6 intake, getting custom tuning, and adding a ported TB. I would also recommend an ASP underdrive crank pulley. Do you know what the car dynoed with stock internals? You can pick up 10+ RWHP with the intake, 10-25 RWHP from custom tuning (depending on how good or bad the stock tuning is doing), 5-8 RWHP from a ported throttle body (depending on quality and amount of port work), 10-15 RWHP in locking the converter, etc. FYI, I gained 15 RWHP in my '98 TA when I locked my SY4000. I would not worry about what it did before because the intake and custom tuning is going to make a significant difference. We have local customer that had another shop's camshaft, Mac headers, and an ORP, and he picked up 8 RWHP from the gain. His a/f ratio was 10:1! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> It was a '98 car as well.
Let us know how it does once the new parts are installed and the custom tuning is complete. Also let me know if you have any particular questions. Keep in mind that I only dyno 369 RWHP with an unlocked converter, and I have every available bolt-on possible with perfect tuning. That got me 11.40's @ over 116 MPH. Keep me posted.
Trevor - Texas Speed & Performance
I figured I could gain a good 10 to 15 rwhp from locking the converter...and the guy told me from what he saw the first pull, I was running way rich, so I'm sure there is power to gain!
I'll definity keep you guys posted!
thanks again
Alex
But, you typically want to shoot for a 12.5:1 AF, 25-28 degrees of timing, and no knock retard. I like the o2's to be arond 900, some folks like to have them leaner than that but 900 is safe and avoids detonation too.
I have found that AF in the 10-11:1 can really hurt rwhp #'s by 10-30rwhp. A big tq number and low hp number is a sign of that sometimes.
Also I dynoed 350rwhp unlocked and 375rwhp locked with a PI3600 a while back (3 years ago), so locked numbers can be much higher. I went 11.75@112 unlocked and 11.76@114mph locked with that converter... I have seen the cam you have go ~11.6@116mph with heads so I kind of expect you to go 11.8 with some traction, would that be a good gain compared to what you ran before the cam?
My best dyno before the cam was 321 rwhp ( with converter locked ), so I know I've picked up some good power, even with the crappy stock tunning.
Trevor, as far as the idle, I knew I was gonna get tunning and a ported TB, so I just drilled the hell out of the stock TB...my idle in "D" was 1200, and in 1500 in Park <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks for all the help.
Alex
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Once I sat down and did some math, I realized I'm not in as bad of shape as I thought I was...
Between locking the TC, LS6 intake, ported TB, and some good tunning....there has to be 35 to 40 rwhp...which would give me some good #s!
I'll make sure I post up once this is all done!
thanks again
Alex
<strong> My bet is get that car to the track & you won't give a crap what it does on the dyno <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">#
Hell yeah! That's my philosophy. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
carter
