ls1 bore/hone
Old 07-14-2005, 01:05 PM
xjjunkie's Avatar
Default ls1 bore/hone
was given a ls1 short block, stock crank,rods,ross pistons,arp hardware. it sat for about 6/8 months, he did spray wd-40 into the cylinders. there is a slight amount of rust on the walls, can the bores safley be touched with a hone to clean up ? also can it be bored at all ?
scot
Old 07-14-2005, 01:09 PM
2002z28's Avatar
i would just take it to a shop and have it flex honed. they will take about 20-30 millionths off the bore. plenty to clean up a real light rust.
justin
Old 07-14-2005, 02:08 PM
krexken's Avatar
These blocks are usually just honed, even when going to bigger pistons. Of course the bigger pistons are only a few thou bigger. Not enough meat there to bore like a normal block. I'll bet you'd be just fine with a light honing.
